New Bobcat Construction Equipment Forum
   / New Bobcat Construction Equipment Forum #1
Muhammad
Administrator
Moderator
San Diego, CA
None currently
Hello All,
We have recently changed the forum structure for Bobcat equipment, which should hopefully better organize the discussions.
Now, you will find a Bobcat main heading on the Forum Index, which contains the following forums:
Bobcat Tractors
Toolcat
I have moved most of the Bobcat-specific posts from the general Construction Equipment to the new Bobcat Construction Equipment forum. From now on, please post your Bobcat-specific questions in the Bobcat Construction Equipment forum.
Thank you!
   / New Bobcat Construction Equipment Forum #2
That's going to split up some of the guys that mulch with Bobcat equipment from others that use different equipment. I think it's a mistake to have a brand specific site for construction equipment.
   / New Bobcat Construction Equipment Forum #3
I agree, if anything I would have a mulching/brushing/landclearing specific forum as a good percentage of the posts here are related to mulching and or landclearing. It may bring more traffic here as well if you have a mulching specific forum, thats the only reason I'm here. There could also be a sub forum for modifications etc repairs for mulching equipment.
   / New Bobcat Construction Equipment Forum #4
I agree on a specific mulching section.
Doing a little research here:
Does anyone have info on setting up a kubota kx 080 for mulching?
The largest bobcat excavators have a hyd flow that might be high enough.
Any brand excavator in the 17-18,000 lb. range could be an option for me.
   / New Bobcat Construction Equipment Forum #7
Did this moderator just do a drive by and not check back? What about our suggestions as we are the ones who use this part of the site. Any feedback?
   / New Bobcat Construction Equipment Forum #8
i agree but if this moderator done it properly..........
   / New Bobcat Construction Equipment Forum #9
I have a Bobcat 3023 tractor with trencher and when it starts pulling hard the drive system disengages and goes into freewheel mode. If you are on a hill it rolls. The only way I can get it to re-engage is to shutdown the motor and restart it. All other hydraulic functions continue to work when this happens.
Any help would be appreciated.
2004 Workhorse Custom Chassis W22 Incomplete Vehicle, VIN # 5B4MP67G143386098 (A53424)
2004 Workhorse...
ROLOFF 500 BBL FRAC TANK (A53843)
ROLOFF 500 BBL...
1982 S&S FLATBED (A53843)
1982 S&S FLATBED...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
