New Brown Disk Harrow
   / New Brown Disk Harrow
I dont have the model number in front of me but its 6ft wide and has 20" disk. Also has the ridge cutters on the back gangs. Its a beast of a harrow.
   / New Brown Disk Harrow #13
AHHHH -
I've looked at the Brown 615 cutter and an 8 foot offset disk harrow until my eyes go blurry. But, no Brown dealers in my area and the freight is a killer. There is no doubt, IMO,that a Brown cutter is one of the heaviest in its class.
   / New Brown Disk Harrow #14
How well does your 3910 handle that plow? Do you think it could pull the 7.5 foot model (BDH-750-2020).
Do those furrow fillers fill in that outside trench pretty good- seems like a great idea.
The 3910 does very well with it but I did need weights on the front or wheel weights to keep front end down on hills etc. A 7.5' should work too and your 3930 has a heavier front end. A lot depends on soil type and depth your disking. If your 3930 is a 98 or 99 model then it has 52 pto hp which helps even more.
   / New Brown Disk Harrow #16
Thanks for that information! The only reason I am interested in the 7.5ft is because the rear wheels on my 3930 are 6.5ft wide and I wonder about the width of the 6ft 4" Harrow being a little too narrow. The Harrow I have now is 7ft wide and looks to be the right width but the discs are worn down and it has recently spit out a bearing.
The 6'4 is fine. It actually covers tracks little wider than that from my experience due to flipping dirt past cut area. Also if you get furrow filler then it spreads dirt even further. I think you could handle the 7.5' too but it will be all the 3930 wants for sure.
New Holland B95 Backhoe (A50490)
New Holland B95...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
