New Bushhog Question
   / New Bushhog Question
Yup small world,
does your firm make the differential telescoping cylinders too?
Not sure exactly which one you are speaking of, but we make several different telescoping cylinders for several mining OEM's.
We make the Bed Raise/hoist cyl's for this truck.
T 282 C
   / New Bushhog Question #22
"We have several tractors and several bush hogs from 4' to 10' and the only way to get one to "smoothly" engage is with a clutch or lever type PTO and even then smooth is a relative term...."
I've seen and read many a complaint over the years about sudden, abrupt PTO engagement on modern tractors resulting in harsh starts and/or broken shear pins. Not a chronic issue or a pandemic, but one that rears its head every so often. The one semi-modern tractor I've spent any serious time with (30 yr old MF) had autonomous PTO and its engagement would normally spin the PTO driveline clutch and produce a carbon cloud no matter how careful I was with it.
Oh well.
One thing, one thing if any, that I do enjoy about the older tractors is the non-Independent PTO. I can spin an implement up or down with the clutch and tractor RPM as I need it to be and see fit. This is just the way I was taught to run a tractor and tool. I do not "engage" or "disengage" one either. I engage the PTO and then apply the appropos amount of power or RPM to get them where they need to be via the clutch and throttle. And vice versa. The way things ought to be, so on, and etc.
Call it the
   / New Bushhog Question #23
T 282 C
Sorry about that Roll center I should have mentioned
that they were for the roof drills/roof bolters.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2019 TAKEUCHI TL8 SKID STEER (A52705)
2019 TAKEUCHI TL8...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2016 Caterpillar 349FL Hydraulic Excavator (A53421)
2016 Caterpillar...
