New BX2380
   / New BX2380 #1
xterra
Bronze Member
Michigan
BX2380
Well got my new BX love it, way better than my 2350. So I'm trying to put my loader on for the first time, must not of got it lined up right cause now it won't go all the way down so now I can't remove it :mur: any suggestions? God I'm so mad.
   / New BX2380 #2
Yes, be careful. There was someone a few months ago that had a similar problem and kind of bent things up. You might do a search for it.
   / New BX2380 #3
As the OP said, yup, be careful. You can go from a nice picture perfect tractor to a bent up mess in seconds.
I've taken a number of loaders on and off in my lifetime on all kinds of surfaces (even inclines), and never had issues. Maybe just operator skill or luck.
The key is to make sure everything is going in the right direction and to take your time. Small adjustments go a long way when hooking up a loader.
Since this is a relatively small system, if you put the loader valve in "float" you can actually move the loader arms yourself using your hands if they get out of whack.
   / New BX2380
Man can't believe i did this, wife is about to kill me. Dealer just delivered it yesterday..lol. How do you put it in float position?
   / New BX2380 #5
Float is all the way up. Past the detent for down pressure.
Float is great for smoothing topsoil or sand out. Or grade control.
   / New BX2380
Looks like you just push the loader stick in the way position and it stays there. Maybe you can move it with your arms then. That’s what YouTube guy said. Guess I’ll go try it.
   / New BX2380
Ok I stand corrected. Thanks
   / New BX2380 #8
No problem. Since it's a new tractor, the float position might take some getting used to until the valve is broken in. Don't be afraid to push it into place.
Good luck.
   / New BX2380 #10
One more thing. Since this is a small loader, if you still can't figure it out, call some buddies over. These SCUT loaders weigh in ~600lbs. Two buff guys can easily move one of these with no problem.
I know it might be embarrassing to ask buddies for help... but what's more embarrassing is messing up the new tractor look.
2013 Ford F-250 Animal Control Truck (A50323)
2013 Ford F-250...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2012 International 4300 Reefer Truck (A52748)
2012 International...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
EZGO (A50324)
EZGO (A50324)
