Dealer New Distribution and Dealer
   / New Distribution and Dealer
Momboy007 said:
Could you possible write me and let me know what would be required on my end to start a dealership in Southern California?
I look forward to hearing from you
Rick
I sent you the message, if not received, please let me know.
   / New Distribution and Dealer #14
Chinese Tractor Man said:
Not the same, headlight and hood sides and others are different.
Yes I see the differences now. It also looks like you have relocated some controls from the center hump.
Couple comments about the Lenar LE304
The lights in the instrument cluster are hard to see in the daylight. May need to get brighter bulbs.
Turn signal is awkward to use in current orientation. Needs direction arrows on button to tell which end to push for which direction.
Levers for rear hydraulics need to be extended and bent differently from each other. Was hard to feel with free hand while moving to get correct handle while not bumping other one.
So far I like what I got. Will get to use her with a tiller in a couple of weeks.
John
John
John,
You are right on the instrument cluster lighter bulbs, I just checked in the morning.
This turn signal was changed as per a customer of Lenar in UK, that is the way in UK and Lenar use such turn signal switch on all LE tractors now. Normally we use the standard switch on the tractors.
Levers for rear hydraulics will be shortened 5cm as it is a little longer and not easy to control.​
   / New Distribution and Dealer #16
Chinese Tractor Man
Thanks for your quick replies. With this level of service your company will do well. ;)
I received the wrong engine parts manual with my tractor. The dealer checked the other LE304's and they had the wrong manual also.
Is there a way to get the right one? Electronic (PDF?) or mail me a copy?
John
jmacshriver said:
Chinese Tractor Man
John
Is the manual marked ZN390T, not 3LS30? It is the right manual as they do not print the new one for the EPA engine model 3LS30. ZN390T and 3LS30 are the different models for the same engine, 3LS30 is an EPA approved engine model.
   / New Distribution and Dealer #18
I did not bring it home with me for the week end, but it was for a four cylinder engine maid by Changchai. Can check next monday for you.
   / New Distribution and Dealer #19
Nice looking tractor. I don't mean to sound suspicious but the attached image, IMG_0091-2.jpg, appears to be digitally altered. The tractor model name and graphics appear to have been added to the image. We all know where these tractors are built, I was just curious about the artwork...
Yes, the decal was made on IMG_0091-2.jpg. Please see the new picture.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
