New Eavestrough with gutter helmet/keep out the leaves?
   / New Eavestrough with gutter helmet/keep out the leaves? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
This coming spring we are going to have new eavestrough installed on our house & garage.Our house is located the woods we want to keep the leafs out of the eves.There used to be a product called gutter helmet to keep the leaves out.Does anyone know of any other products out there?We did have those 4ft clipped on do hickeys on the old eves with the mesh screen and they held up fairly well just looking at all options.Thanks.
   / New Eavestrough with gutter helmet/keep out the leaves? #2
I have had the Gutta Gard for almost 10 years now. It works very well. Similar to the gutter helmet concept. Just solid aluminum that allows the leaves to slide over and fall down on the ground, and the water curves over the large curved leading edge and down into the existing gutter. The only time you see some water coming off down over that curved lip and hitting the ground is during a "toad strangler" any kind of normal rain it just goes in the gutter. I haven't cleaned the gutters since it was installed. It still work, and all of the downspouts run fine. It is raining today. You can install it yourself. I had the roofers install mine while they were up there. They did the whole house in maybe 15 to 20 minutes. I think I paid about a dollar a foot.. Probably more now.
eGutter ® - High Quality Gutter Guards In Copper, Aluminum, Galvanized Steel, And PVC Shipped Direct To You.
Gutter Protection - GuttaGard | Gutter Guards | Gutter Supply
Gutter Genius - utter Genius - Gutter Protection is a high quality, solid metal gutter protection system that outperforms most of the expensive national brands at a small fraction of the cost. It installs simply and easily using a flat edge tool
   / New Eavestrough with gutter helmet/keep out the leaves? #3
This is a good time of year to look for a large home show to see lots of these products all at once. There are several available now to compare.
   / New Eavestrough with gutter helmet/keep out the leaves? #4
One thing to keep in mind .... those solid types work well but they make a great place for yellow jackets and paper wasps to build nests!!
   / New Eavestrough with gutter helmet/keep out the leaves? #5
I use something similar to Rhino guards. Home | THE RHINO I like the mesh top as it stops granules from collecting in the gutter. Once a year I take a broom up and brush them off, usually after the spring pollen dump.
   / New Eavestrough with gutter helmet/keep out the leaves? #6
I've got several water maples around my house, they used to fill the rear and west side gutters full of the little "helicopters" in the spring and large leaves in the fall.
I went with Gutter Brush because of a friends recommendation and a decent discount that was offered at the time. Large black brushes, 3' long that just slide down inside the gutter and the bristles keep all the junk from reaching the gutter. Over time, they dry up and get blown away by the wind. I haven't had them in very long, but this was the first year since I've been here that I didn't have to do a Fall gutter cleaning. Fairly inexpensive, easy to install.
   / New Eavestrough with gutter helmet/keep out the leaves? #8
I am surrounded by Maple trees. Have tried various types of screen and mesh but debris (leaves, seed, and sticks) would build up to point rain water just went over top of the gutter and require cleaning the screens. 14 - 15 years ago I had Leaf Gutter system installed and have not had to do any gutter maintenance at all. Extremely satisfied with this system.
Well I got my estimate today.Our house is 58ft long X 28ft wide garage is 28ft long.The final estimate was $831 5 inch gutters .25 thickness with 6 down spouts.The Are Your Gutters LeaFree?? (brand name) cover was another $1630 bucks,ouch.
   / New Eavestrough with gutter helmet/keep out the leaves? #10
Have friend with house in the woods, he uses gutter brush and loves them. Three to four years old
UNUSED Safety Traffic Cones (A50860)
UNUSED Safety...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
UNUSED 400PCS 39 in. Zip Ties (A50860)
UNUSED 400PCS 39...
2001 Nissan Frontier Crew Cab Pickup Truck (A48081)
2001 Nissan...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
