Robert_in_NY
Super Member
- Joined
- Aug 1, 2001
- Messages
- 8,586
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I just came back from a grape growers meeting sponsored by one of our fertilizer dealers and the local John Deere dealer. They had a 5425N there as well as a 100F with cab. While I have never been in either before I did feel comfortable in the 5425N although the cab is narrower then the New Holland TN-F. Another point where the N series Deere is lacking compared to the New Holland is the turn radius. The only way Deere dealers can get the N's to turn closer to the New Holland is to put wheel extensions on the front axle which then make the front axle wider then the rear wheels. The Deere cab sits higher then the New Holland which in a normal vineyard is not a problem and it is better as you do not have as large a transmission hump in the cab of the N Deere as you do the F series New Holland.
However, I did not meet any grower there that liked the cab on the 100F. The 100F is John Deere's import to compete with New Hollands TN-V which is a tight but useable tractor. The 100F is only 6' tall to the top of the cab. The top of the cab is a bulge where you head sits. If you are six foot tall you bump your head getting in and out of the cab. If you are short legged you will have trouble stepping over the center hump of the tractor. Two of the guys there (one was a friend) had a 23" and a 24" inseam and neither could get in the cab comfortably. Even for me being 6' tall I had trouble getting in or out and once in there was no room at all to move my legs even a little. I could not see sitting in this tractor for an hour let alone a day and forget having to get in or out of it multiple times a day.
One other issue I didn't like is the transmission. It is a dual tranny in that if you have a lever mounted below the steering column in one position it is an 8x8 tranny with the shuttle mounted on the left of the dash. However, if you flip that lever below the steering column it becomes a 16x8 transmission. That is all fine and good but that shuttle lever on the left of the dash is no longer a shuttle. It is now your splitter lever (similar to the dual power option on the Fords in that it reduces your speed around 20% or so). Instead, the shuttle lever is now a lever to the left of your hip.
The tractor had some nice features like auto locking front differential but I can not see John Deere selling very many of these in the US as they are too cramped and too complicated. If you have helpers on your farm they will not like using this tractor and you would have to train each and every one of them on how to even shift the tractor.
One other thing I didn't like is the fuel port is in a terrible location. It is located half under the rear window making it a pain to access.
I doubt very many of you guys will ever use let alone see one of these tractors but for those who might this is my first impression of it. Also, it is priced higher then the N series Deere. The 100F was $45,500 while the 5425N was $41,900. To be fair the 100F is closer to the hp of the 5525N but the 5525N is still cheaper.
They did touch on the Goldini made John Deere 20A also but didn't have one there to see.
100F
5425N
20A
100F
5425N
20A
