NEW FARM OWNER
   / NEW FARM OWNER #11
Welcome aboard!! You will find tons of useful information to help you decide on what tractor is best for you. Don't be afraid to check out all the brands and test them out.
   / NEW FARM OWNER
As i research tractors, can someone explain loaded tires?
   / NEW FARM OWNER #13
Loaded tires are tires filled with a liquid.
Some liquids are:
Water & Calcium....(very corrosive)
Water and anti-freeze
Water & Window Washer Fluid
Beet Juice
Rim Guard
The idea is to add weight via loaded tires. (and the weight is low and it does not take up your 3 point hitch as a ballast box / box blade would) (Also, many people use both loaded tires and a rear box)
Rim Guard has a nice page that explains how many gallons are needed for your tire size and what the added weight would be per tire
Rim Guard Hydro-Flation Tables for Agricultural Tires | Drive Wheel Tires | Terra Tires | Light Construction Tires
example:
an R4 tire sized...15-19.5...needs 29.0 gallons per tire...and adds 310.3 lbs per tire
Search the forum for loaded tires and you will have more than enough posts to read from now until Christmas
LOT# 184 GRACO BULLDOG PUMPS W. NAUMATIC LIFT CYLINDERS (A59213)
LOT# 184 GRACO...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
2003 Club Car Electric Utility Cart (A56859)
2003 Club Car...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
UNUSED MOWERKING SSRC 72" HYD BRUSH CUTTER (A58376)
UNUSED MOWERKING...
Traverse Lift 8040 (A55272)
Traverse Lift 8040...
