New Fence
   / New Fence
Thanks for the nice comments on the fence. It wasn't easy getting the rails just right- I first just did them level with step downs but ended up removing them and doing it by eye to best match the slope of the ground (trial and error).
I didn't use concrete, I did add gravel to each hole for drainage. I was concerned if I wanted to remove the fence that dealing with the concrete would be a pain- also the infill is wire, which is much lighter then a wood infill and allows the wind to blow through. Tamping is a painful job, but the posts seem quite stable.
I used a 9" auger on the PHD- I have an underground sprinkler system and the posts went between a mainline and a sprinker line so I couldn't safely dig a bigger hole. It also meant less hole to fill in. A 12" would be more forgiving when you dig a hole that's off center of not quite straight (which happens all the time). If you do buy a PHD- keep in mind a lot of companies make a smaller one to fit subcuts that digs about 36"- the regular size one will dig to about 42"- if your tractor will handle it, the bigger one would be better. It's a great implement and I'll be digging some holes for trees soon as well.
   / New Fence #12
That's good information. I've set a few posts using rock, and they are very stable. We will be replacing several hundred feet of barbed wire on our place (~19 acres). Barbed wire is not good with horses. My tractor will work well with the larger PHD (Mahindra 6000). I'm planting trees as well, so yet another reason to purchase.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2014 FORD F-350 SUPER DUTY (A52472)
2014 FORD F-350...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
