New floor for the trailer
   / New floor for the trailer #1
PM Wells
Foothills Of The Blue Ridge NC
84 Massey Ferguson mf 250- 95 Massey Ferguson mf 253
I bought a Hudson 5 ton 6.6x 14 trailer that had been setting for a few years, course it has some surface rust on it, the treated floor was weak in places, it is a 2000 model so I guess the floor held up pretty good. I want to put a new floor on it and have thought about red oak milled down to 7.25 x 1.5 or just replacing with the treated yp like was on it. Also I am thinking about spraying a rust converter on the frame and then a industrial paint, any one have ideas on the floor or the paint? Thanks
   / New floor for the trailer #2
Red oak will rot use white oak it will last a lot longer than treated lumber...
   / New floor for the trailer #3
I redid a couple of mine with 2x12 fir, they have held up really well. I don't remember what I used for varnish. Can't help on the paint, I know nothing about that:)
I may just go back with treated 2x8 like was on it
   / New floor for the trailer #5
I need to refloor my GN.
How do you plan to get the old floor off?
The floor was fastened down with 5/16 star drive screws into the cross members, course they were rusted and would not back out. I drilled down beside them with a 5/8 steel bit through the wood and pried the wood up with a 4x4, then cut the screws off with a metal blade. I am planning to use a rust converter that works as a primer on the frame
   / New floor for the trailer #8
Treated wood comes in different treatment levels. Typically trailer manufactures use the cheapest such as used on decks and it rots much too soon. Replace with 1st choice order CCA preservative lumber (it hasn't been outlawed but needs special ordered). It'll last 20 plus years easily. 2nd choice critical structure grade. This can be direct burried. 3rd choice ground contact grade. Don't buy standard above ground grade.
All treated wood is corrosive to metal. Use galvanized fasteners and undercoat where wood touches trailer.
The treated wood on my new trailer only lasted 6 years before getting soft in places.
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2013 CATERPILLAR 559C KNUCKLE BOOM LOG LOADER (A52705)
2013 CATERPILLAR...
2018 Ford F-150 Ext. Cab Pickup Truck (A55788)
2018 Ford F-150...
Famall Cub Tractor (NOT RUNNING) (A50775)
Famall Cub Tractor...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
