new grand l 60 series.
   / new grand l 60 series. #41
Possibly skid steer quick attach?:confused3:
That's what I'm hoping for, but wasn't sure if anyone knew for sure. I'll probably just contact the dealer to see if they can elaborate more on it.
   / new grand l 60 series. #42
Matt
You mentioned possibly posting the new Grand L60 series as a PDF. Would you still do it? I'm not concerned about it being in color as much as I just want to look at the specs.
LAM
   / new grand l 60 series. #44
penny40,
I apologize, however, I had to return the brochure to the very kind source. I expect we'll see it available openly shortly...
Regards, Matt.
   / new grand l 60 series. #45
its not skid loader QA, it looks the same.. but the plate is more narrow.
Thanks a bunch for the information. It wasn't obvious what the dealer was talking about when I first read it on their web site (and the dealer never responded to my email when I inquired about it.)
Also, do you have any idea on when the B3350's are likely to be available at dealers?
   / new grand l 60 series. #46
I read this on a local dealers website:
* New B2650 and B3350 Cab Tractors, larger cabs, high performance a/c, universal quick-coupler
Does anyone know what the "universal quick-coupler" is? It's definitely got my curiosity.
Somewhere on another thread here on TBN I saw somebody referring to the Canadian version of the B50 - and it clearly showed a skid-steer type QA for the FEL.
What I'm wondering is: could I retrofit this onto my B3200 ??
   / new grand l 60 series. #47
Can you explain? Do you mean the overall width of the whole thing is narrower than a standard skid steer QA?
Do you know if there is any interchangeability at all with standard skid steer?
If it's completely different in all dimensions - that would sort of suck. If it was at least "semi" compatible that would at least make using skid steer type attachments not too bad if minimal mods were needed.
   / new grand l 60 series. #48
I had the brochure for the Canadian version of the B50 open on my work PC.
Link is here:
Products: B2650 Kubota Canada Ltd.
Also check out the attached picture (from the Canadian brochure) . One of the interesting things is that the lockdown pins - are basically located almost
inline with the loader arms. Last year after buying my B3200 I did a bunch of research on the feasibility of adding a skid steer type QA to the LA504 loader. And one of the main problems I remember there being - was that in order for the lockdown pins to line up with the standard location of the hole in the bottom of the skid-steer QA plate - they have to be almost lined up with the arms for the FEL. Which presents a packaging problem (I was contemplating making one).
Judging by the picture - looks like Kubota may have solved that problem. But I will reserve judgement until I actually see one "live".
Anybody have any idea when the B50 is due to actually hit the market?
   / new grand l 60 series. #49
Jim, this would tell me that the new B owners are in a similar boat as us older B owners in that the new QA is proprietary, and thus, would require Kubota-only or owner customized attachments.
The question is how much does getting off the machine to deal with the pins create a problem for you (keep in mind a true skid steer QA or even the new B50 QA means you need to get off the machine). I think the only skid steer QA option for the older B series is still the ATI setup. One potential problem with that, which is why I stuck with the pin-type QA, is the significant additional weight of the skid steer QA setup & attachments, impacting FEL capacity.
The one slight advantage to the pin-type QA is that you can purchase any pin-on attachments that fit the B series loaders, which are offered by quite a few aftermarket companies. Not as big a selection and possible cost savings as the true skid steer QA attachments, but the key is the weight savings with this setup. And a lot of the lighter duty attachments for our B series are still cheaper than the heavier duty units built for skid steer QA equipment.
   / new grand l 60 series. #50
right. it looks like an SSL QA, but the plate is more narrow and thus any SSL stuff would have to be modified to fit. Yes, we pitched a fit about it. You can still buy a QA from ATI if you want one. We've used them for years.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
Pallet of 10 Chains and 5 Binders (A57454)
Pallet of 10...
2004 Thomas Bus (A57148)
2004 Thomas Bus...
1991 CAT D7H Crawler Dozer (A59213)
1991 CAT D7H...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
GENIE S-60 MANLIFT (A58216)
GENIE S-60 MANLIFT...
