New holland 3930?- where do you put in hydraulic fluid.
   / New holland 3930?- where do you put in hydraulic fluid. #1
AlbertC
Perry, GA
New holland 3930
I just changed the hydraulic filter on my 3930 for the first time since I bought it (used tractor) I probably lost a qt to half a gallon of fluid. I looked in the manual and can't find anywhere where it tells you where the refill is. I also can't find if there is a dipstick to check the fluid level.
Does anyone have a 3930 who can tell me where to refill the fluid and also tell me if there is a dipstick to check the fluid level.
Thanks, and yes I feel like a dipstick for having to ask this question!
   / New holland 3930?- where do you put in hydraulic fluid. #2
I'm thinking both are near the gear shift, been a while since I've been around one though.
   / New holland 3930?- where do you put in hydraulic fluid. #3
The rear end oil where the hydraulic filter draws from is checked by a dipstick from the back of the tractor on the LH side above the axle housing. Filler plugs are the 2 large plugs on top of the rear end behind the seat. If you have deluxe remotes, then the filler is on a tube sticking up behind the seat.
The transmission check is the large plug/dipstick on top of the transmission.
2016 MACK CXU613 DAY CAB (A52141)
2016 MACK CXU613...
2016 Ford Explorer...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
