New Holland 845 Hay Baler
   / New Holland 845 Hay Baler #1
tractorboy5500
Conroe TX
Mahindra 5500 4WD, 275 FEL
I bought a NH 845 hay baler last week for $500 from a friend that wanted to get out of the hay work, It worked last season he said and have some wear and tear on it. When I got it home I cleaned it up and hooked it to my tractor, it all works like it supposed to. I got to looking at all of the moving parts, 2 out of the 7 floor chains needs replacing and 5 out of the 7 chain trays need replacing and the floor bottom, I have the metal for the floor, just in the process of ordering the other parts, all of the drive gear looks and operates good, and the apron chains look in good shape, I will take the tension off to check all of the bearing, just havent got to it yet.
This hay baler has chains, not belts, any tips from the pro,s out there??? thanks
   / New Holland 845 Hay Baler #2
keep the floor chains tight and oiled and dont fall off the tractor are u will be baled up i have seen these little balers pick up some pretty heavy stuff
I tried to tighten them up, with the adjustment screw, but two of the chains had to much wear on them, they were all loose, while I have it torn apart, I have been working on cleaning and painting the underbody, just have it primed for now till I get some paint from TSC.
I have a manual tie, I never used one but I guess after a few times or wrecks I will figure it out.
2019 INTERNATIONAL LT625 SLEEPER (A50046)
2019 INTERNATIONAL...
2010 VOLVO VNL TANDEM AXLE MID ROOF TRUCK (A45679)
2010 VOLVO VNL...
2011 Ford Fusion SE Sedan (A48082)
2011 Ford Fusion...
Lyom-053 Unassembled Safety Basket Forklift Attachment (A46683)
Lyom-053...
2022 CATERPILLAR 349 EXCAVATOR (A50458)
2022 CATERPILLAR...
2013 Ford E-250 Animal Control Van (A48081)
2013 Ford E-250...
