New Holland Baler and haybine Numbers
   / New Holland Baler and haybine Numbers #1
wolfgreyt
NH 4060
I have been looking at various New Holland small square balers and hay harvesting implements in local auction listings.Can anyone advise of a website/ reference list where Model numbers and specs are listed of older NH small balers and haybines are listed.It would greatly reduce time of my search although I don't usually need an excuse to go to an olde farm auction.:D
   / New Holland Baler and haybine Numbers #2
Here's a partial answer to your question, info I've compiled while browsing...
77 NH SQUARE BALER (4/49-10/53)
S77 NH SUPER SQUARE BALER (10/53-7/57)
S66 NH SUPER SQUARE BALER (8/55-9/57)
78 NH SQUARE BALER (7/57-8/58)
S68 NH SUPER SQUARE BALER (8/58-10/60)
98 NH SQUARE BALER (4/57-2/60)
S78 NH SUPER SQUARE BALER (8/58-7/61)
65 NH SQUARE BALER (8/60-2/65)
99 NH SQUARE BALER (2/61-5/63)
270 NH SQUARE BALER (8/61-7/63)
280 NH SQUARE BALER (8/61-7/64)
271 NH SQUARE BALER (8/61-7/64)
268 NH SQUARE BALER BELOW S/N 12777 (7/63-7/64)
268 NH SQUARE BALER ABOVE S/N 12778 (7/64-6/68)
281 NH SQUARE BALER (8/64-7/66)
269 NH SQUARE BALER (8/64-6/68)
272 NH SQUARE BALER (7/64-6/68)
290 NH SQUARE BALER (1/64-2/76)
275 NH SQUARE BALER (1/66-5/71)
282 NH SQUARE BALER (8/66-5/72)
285 NH SQUARE BALER (11/67-4/72)
277 NH SQUARE BALER (11/68-5/72)
273 NH SQUARE BALER (7/68-7/77)
276 NH SQUARE BALER (7/71-6/76)
283 NH SQUARE BALER (8/72-4/77)
320 NH SQUARE BALER (8/75-5/84)
286 NH SQUARE BALER (8/72-5/77)
315 NH SQUARE BALER (8/76-4/82)
500 NH SQUARE BALER (10/76-1/83)
425 NH SQUARE BALER (11/77-10/82)
420 NH SQUARE BALER (10/79-11/82)
311 NH SQUARE BALER (8/81-7/88)
316 NH SQUARE BALER (9/82-1/89)
505 NH SQUARE BALER (1/84-3/91)
326 NH SQUARE BALER (7/85-7/88)
565 NH SQUARE BALER (7/88- )
570 NH SQUARE BALER (7/88- )
575 NH SQUARE BALER (7/88- )
585 NH 3-TIE IN-LINE SQUARE BALER (1/97-4/99)
BB900 NH 3-TIE INLINE SQUARE BALER (10/00- )
Thank you thats a great start, do you know if the numbers can be broken down by baler size ? I.E. which are the small ones?
   / New Holland Baler and haybine Numbers #4
All make 14x18 bales except the following: 65,77,S77,78,S78, 98, 99,
280,281,283,285,286,290,420,425,426,430,
500,505,585,BB900.
   / New Holland Baler and haybine Numbers #5
That's a code I haven't fully broken yet. The newer lines they have out seems to make a little more sense, e.g. the current models are:
BC5050 35 hp PTO
BC5060 62 hp PTO
BC5070 75 hp PTO
BC5080 80 hp PTO
and the last gen models seem to match those:
565 35 hp PTO
570 62 hp PTO
575 75 hp PTO
580 80 hp PTO
But the older ones? I was looking at a 315 and asked around what was hp was needed for that model, I got answers from 40 to 90 (90 was w/ kicker) So... ???
   / New Holland Baler and haybine Numbers #6
Most 14 X 18 balers can be operated with less than 50hp. NH tends to require higher HP where JD, for the same number of strokes and baler weight, will require less. Often the issue is the weight of the baler. A smaller tractor will get bounced around by a bigger bailer. None of the square balers have anything new to require more HP. I just got rid of a 30 year old IH-37 baler and got a new JD. The only real difference is the flywheel is on the side and the paint is nicer.
   / New Holland Baler and haybine Numbers #7
The newer New Holland offerings have low hp model(s), then higher hp models. From above:
565 35 hp PTO
570 62 hp PTO
575 75 hp PTO
580 80 hp PTO
The 570 and above are considered "high capacity" balers, the jump from the recommended hp requirements of 565 to the 570 coincide with the plunger strokes per minute - the 565 is around 70, the others are 90+. I know the 5050 has a completely different feed mechanism than the 5060, 5070, and 5080 as well.
I don't know why I care about any of those though, I don't have $25K to spend on a baler, so most of our "new" balers are at least 30 years old... :D
   / New Holland Baler and haybine Numbers #8
Hi there, I was happy to see the list above,
I was looking for performance of those machines.
I actually own a NewHolland Sperry 315 and wanted to go bigger.
I can make 275 bales of hay per hour with my 315 and was looking to do even more.
Does anyone know about a baler in about the same generation (meaning price) that could do above 300-400 bales per hour.
THanks in advance
   / New Holland Baler and haybine Numbers #9
Theoretically, if you're making bales with 15 flakes per bale, a plunger speed of 105 strikes per minute will give you 7 bales a minute, which is 420 per hour. That's obviously best case - ideal windrows, no turns allowed :)
I think most of the high capacity NH offset balers are 90 stroke max?, and I think the 315 is 79? That would yield a max of about 315 bales per hour, so all things considered looks like you're managing about 87% of max, applied to a 90 stroke machine that would only push you up into the 320 bales per hour range.
The newer 105 stroke machines (which I understand you don't want to spend the money on) would be at about 365/hour (at 87%)
That's all back of the napkin stuff, obviously. But it should be pretty close - I just baled 190 bales in a very less than ideal field yesterday with my 311 (70 strokes per minute) in about 50 minutes...
   / New Holland Baler and haybine Numbers #10
The 575 High capacity is rated at 94 strokes a minute at 540. I know, I have one. It kicks butt.
It is also a power hungry unit. 75 pto is conservative at maximum capacity.
2021 Kubota L2501D 4x4 Tractor with Loader (A44391)
2021 Kubota L2501D...
1998 KBH Fertilizer Tender Auger Trailer -30 FT (A46877)
1998 KBH...
2009 Mack Hood (A44391)
2009 Mack Hood...
2009 Kenworth T800 Truck, VIN # 1XKDP4EX69J245973 (A44391)
2009 Kenworth T800...
MLE 4188CR Clean Room Scissor Lift (A44571)
MLE 4188CR Clean...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A44391)
2007 International...
