New Holland LOADER safety notice!
   / New Holland LOADER safety notice! #11
Thank you very much, I know what to go lok at tonight.... /forums/images/graemlins/grin.gif
   / New Holland LOADER safety notice! #12
I got mine yesterday too. Wasn't too sure what to look for. Wasn't overly concerned about it at first - until I saw what and where it was happening. Guess I'll be making the call here in a few minutes....... /forums/images/graemlins/frown.gif
   / New Holland LOADER safety notice! #13
I got one as well, it does state "To eliminate this concern, your New Holland dealer will install a new fitting". They probably have a lower profile piece to put on there.
   / New Holland LOADER safety notice! #14
Actually they are replacing the fittings with a new lower profile fitting. They are not turning the cylinders over.
   / New Holland LOADER safety notice! #15
</font><font color="blue" class="small">( Actually they are replacing the fittings with a new lower profile fitting. They are not turning the cylinders over. )</font>
That's what I figured. It really is a good design with the fittings well protected, they just didn't allow enough clearance by a very small fraction of an inch. Probably won't even be able to tell the difference with the new fitting unless it is a different style.
My dealer thinks they will probably take care of things as a field visit, not sure until they get the parts in.
Brad
   / New Holland LOADER safety notice! #16
<font color="blue"> Actually they are replacing the fittings with a new lower profile fitting. They are not turning the cylinders over.
</font>
You guys should have all taken my money on that bet. You'de all be drinking beer on my money if you did.
   / New Holland LOADER safety notice! #17
I had a look at my 18LA FEL and the fitting is located like on the 16LA, offset 90° from the one in the back. Guess we got lucky there. /forums/images/graemlins/crazy.gif
   / New Holland LOADER safety notice! #18
I looked at mine last night. Mine has "hit" yet, but I could see where if I got a piece of dirt or rock in there how it could be a bit of a problem. Though while I was looking around I noticed I did have some type of fluid leak. /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif. It is on the left side of the transmission housing, running right down behind where the clutch linkage is. Guess now I have to add something else to my list for the dealer to take a look at and fix before the warranty runs out.....
   / New Holland LOADER safety notice! #19
I just checked my 14LA (2004 TC33DA, Manual Trans, 14LA Loader and lots of other toys) and the fittings are at 90 degrees to the top, so there is no risk of hitting the loader frame. /forums/images/graemlins/grin.gif
Have a great day!
Chris
Spotsylvania VA
   / New Holland LOADER safety notice! #20
I fianlly went and looked tonight. I have different fittings than Brad has on his. I have not received a recall as of yet either. Maybe mine is newer /forums/images/graemlins/confused.gif and has already gotten the new fittings. Although I'm approaching 2 years soon?
PALLET OF TILE (A58374)
PALLET OF TILE...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2323 (A58376)
2323 (A58376)
MODEL 14C SCRAPER (A58216)
MODEL 14C SCRAPER...
