new holland or case ih ?
   / new holland or case ih ? #11
If you are still In the shopping.....
Keep in mind that so TD series NH will have a dry clutch (no power shuttle). If the clutch on the TD has not been replaced it will need to be soon and approximately every 1,000 hours going forward.
Both tractors are over priced. Your dollar will go a lot further if you can swing buying out of state wo. That Farmall 75c with the odd ball Stoll loader with 4000 hours of shoveling **** is 2wtoast. Watched a 2013 identical New Holland with less than 300 hours go for $19k. You can get alot of tractor in good shape with decades of life left for under $20k.
As far as the Farmtrac...no
If it ain't Ford/NH, CIH, JD, or Kubota the odds of you ultimately being satisfied with your purchase drop drastically.
Yeah, I am still shopping. Just last week I switched to looking out of state and there are a lot of better deals outside of New York. I would preferable like to be under 18k as far as spending goes. I only need something 65-80hp range. I can be flexible. I need the loader and if it has a third function then that would be even better..I'm not liking the way the NH Workmasters look and most only have 1 set of ports in the rear.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
golf cart electric (A55787)
golf cart electric...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
