New Holland TC 30 won't start
   / New Holland TC 30 won't start #21
Mine turned out to be defective cable end.Wasn't getting tight enough
I’m still having a random issue . Next days off I will check the cables .
Consider bypassing the seat switch.
I unhooked all sensors and nothing.Twisted cable around some and bam it cranked up.Done cleaned it too much.Tightened cable up till i almost broke the end.It has started and ran like a top since. :)
   / New Holland TC 30 won't start #23
Well I’m still having a problem . I checked my battery terminals . They were dirty . Didn’t help . Talked to the dealer and told me maybe starter relays . Gave me 2 relays . Changed the ones he said . Didnt help .Should my tractor start with out sitting in the seat ? Cause it will .
   / New Holland TC 30 won't start #24
Yes I believe it should start without being in the seat if it is in neutral, the the PTO is disengaged & the brake is on... at least that is how my TC40D works.... I start it all the time without being in the seat...
Also you may want to check your cables... not just your connections...
Older New Holland battery cables often corrode inside the terminal where it is sometimes impossible to see; You will often have voltage so everything seems good. (gauges & all are working) but no start.
You can test if there is an issue with your existing battery cables pretty simply.
Remove the negative battery cable & then take a negative jumper cable wire and place it on the bare negative post of your tractor battery. Connect the other end to a solid clean ground of the tractor (bare metal location). Try starting the tractor & see if that makes a difference...
If that doesn't change anything you can do the same process on the positive post. Disconnect the Negative jumper from the Battery terminal. Then using your positive jumper cable attach one end to where the positive battery cable connects to the starter (connect this end first), and the other end to the positive battery post (last). Make sure the jumper cable is not able to arc to near by metal. Now reconnect the Negative jumper cable to the battery & try starting the tractor again & see if that changes anything...
Doing this process you basically bypassed the battery cables on the machine, and then can troubleshoot from there. I wouldn't put any more parts on it till I checked the factory cables...
   / New Holland TC 30 won't start #25
Thanks , if I don’t get called to work tomorrow I will try this .
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
Informational Lot - Shipping (A55301)
Informational Lot...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
