New Holland TC30 No start/no crank
   / New Holland TC30 No start/no crank #1
JodyFKerr
Multiple
Hi Folks, forum newbie here.
Trying to fix a friend's NH TC30. It came to me in a no start no crank fashion. I've read through the manual and the many posts here, but still no fire.
Battery is good, tested with second known good battery as well.
Cleaned all terminals/wires. Checked positive terminal wire for breaks/corrosion.
Jumpered the brake, pto, and neutral safety switches.
Pulled and replaced all fuses.
No start with key, but will crank when I jumper the starter solenoid. Been working my way backwards through the wiring and have reached the Safety Start Relay. Is there a way to test this? I don't see any tests in the manual. I'm starting to wonder if it's the issue as I'm also not getting 12v to the fuel shutoff solenoid.
I apologize as this is not a tractor that I'm familiar with. My friend passed a while back and I'm trying to get it going again for his wife.
Jody
   / New Holland TC30 No start/no crank #2
I would look into the Sticky at the top of this section.
TC33D wont start
It sounds like you are having the same problem with the ignition switch maybe.
   / New Holland TC30 No start/no crank #3
Jody-
Welcome to TBN. Is the little metal tab seat contact for the seat safety "kill" switch making contact/connection with the safety relay switch?. Mine rusted and broke off. I bypassed that relay. Good luck.
   / New Holland TC30 No start/no crank #4
Jody
What are the numbers on the bottom side of the relay you mention? Relays are often similar with the different pin positions indicating coil and contacts, NO or NC = normally open and normally closed, etc. Have you checked to make sure nothing like a PTO switch is engaged? If it is the tractor will be in lockout for fuel and starter cranking. Why would you jumper it - is it not a on/off position switch?
If you can locate a wiring schematic for the tractor that would help too.
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
UNUSED DEERE FAMILY AR500 3/8" STEEL SHOOTING TARG (A58376)
UNUSED DEERE...
SKID STEER ATTACHMENT PACKER (A58216)
SKID STEER...
