New Holland tc45 bottom end knock
   / New Holland tc45 bottom end knock #1
jjaphipps22
Bronze Member
Fredericksburg, VA
New Holland TC45S, Ford 1620-Sold, Ford 4100-Sold, Hinomoto C174-Sold, Allis Chalmers 5015-Sold, Farmall Super C, Farmall 140
I just got this tc45 running but I bought it from an older lady and she said it has not been run in at least 5 years. Once it started it had a very loud bottom end knock. I have not removed the pan or filter yet but if anyone has any ideas I am all ears.
Well after pulling the oil pan last night I found a lot metal shavings in the bottom of the pan (kind of copper colored on one side). Since i started this thread the tractor has sat in my driveway and leaked probably somewhere around 2 quarts of oil, this came from leaking seals around the drain plug bolts. I didn't get a lot of history on this tractor because I purchased it from an older lady who's husband had passed away and all she said was it had engine problems. But now knowing the tractor was leaking oil profusely I believe someone started this tractor after it had sat for a while and leaked most or all of the oil out of the engine and this caused a rod bearing to spin thus causing the knocking sound and validating my suspicion all along that this was probably the most likely cause for the engine problems she kinda described. The next course of action will be to check the crank and figure out if a total tear down splitting of the tractor is required.
   / New Holland tc45 bottom end knock #3
Good luck with the work. Please post some pics of the machine. I hope you got a good deal on her.
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
Kubota RTV X900 (A53317)
Kubota RTV X900...
