thclimer
Veteran Member
I have had starting issues since I purchased my 2000 New Holland TC45D about a year ago. It has 1366 hours. Every so often when I try to start the tractor, I turn the key, wait for the glow plug light to go out and then turn the key to start and there is a click and no start. The instrument panel lights flicker and you can hear a wine in the fuse area. At this point, the instrument panel lights do not light up as normal. When I turn the key, the glow plug light does not come on, the Oil light is on and the battery light is dim. Only if I disconnect the battery for a few seconds will the lights go back to normal when I try to start the tractor. (glow plug on, oil light on and battery light on)
It used to blow the 2nd fuse in from the left which was a 10 amp fuse. I replaced it with a 15 and it solved the issue for a while.
I took off the starter, connected it to power and it spun and seemed to work fine.
I reinstalled the starter, turned the key on 1/2 way to let the glow plug light warm up and go out, tried to bridge the power from the starter to the 12v solenoid and "click", it did exactly what it does when I try to supply power to the starter with the key. Instrument panel changes, there is a wine, will not start.
I really don't think its the battery although I have not tried jumping the tractor. I did try starting it with a car charger "start aid" setting, it did the same thing, need to disconnect the battery to reset, than try to play with fuses,
This issue has happened after washing the tractor. I think its an electrical issue but haven't found any frayed wires.
Any help is appreciated.
John
While your tractor is 45D the following Sticky Post might give you some insight for issues to check:
https://www.tractorbynet.com/forums/new-holland-owning-operating/124642-tc33d-wont-start.html
