NEW HOLLAND TN65 WON'T GO INTO GEAR (WON'T MOVE) CODE 47
   / NEW HOLLAND TN65 WON'T GO INTO GEAR (WON'T MOVE) CODE 47 #1
tractor13678
wickliffe
kubota l3400
I have a New Holland tractor TN65. While driving the clutch felt like it was slipping. I started it the next day and it would not go into gear. I put it in forward and as soon as I let out the clutch the Power Shuttle light comes on and flashes code 47. I replaced the clutch potentiometer and still have same concern. It has a HI/LO electro-hydraulic power shuttle trans. No clutch cable. It has clutch potentiometer. Any known concerns or help please. I think it is a 1998. I also had a codes 37 and 59 but after replacing clutch potentiometer the only code i have is 47.
   / NEW HOLLAND TN65 WON'T GO INTO GEAR (WON'T MOVE) CODE 47 #2
I found this on the web it might work :confused3: It's a 5v circuit. Back probe wires. Signal wire should have 4v when right up and between .6v to .8v when pushed down. Recal pedal by leaving key on, unplug pot for 5 secs then plug back in. Dash should beep and n light blink. Push clutch down slowly and hold until beeping stops. Key off to store
Thank you Peter. I will be working on it Monday. Is this to reset new clutch potentiometer switch? Where did you find this procedure?
Thank you! I will try Monday.
I tried that and id did not work. 4.3 volts when up and 0.7 volts pushed in.
Still get code 59 when you turn key on put in forward or reverse and let out clutch. Tractor running I get code 47. If i adjust the clutch switch a little i will get code 37 sometimes.
Do you need a special scanner tool to reset system?
Thank you PETER.
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
CLUB CAR (A55758)
CLUB CAR (A55758)
