N80
Super Member
Still don't understand the problem with the Kubota. I have an L4400 and have mowed for hours on end in 95 degree heat and deep fescue and brrom straw and the needle barely budges above the cold end pin. When I get into high broomstraw the needle will start to rise....after hours of mowing. I pull the screen out. Knock it against a tire and I'm off again. No problem.
If your Kubota won't perform at this level this is a problem with that particular tractor. If you like the tractor otherwise, then find the problem and fix it. It is unlikely (impossible) that this is a brand issue or even a particular model issue. So if you can't find the problem on this tractor, sell it and consider an M7040.
When you try to sell it for $24K will you tell the seller it overheats?
