New Holland Tn75f engine trouble
   / New Holland Tn75f engine trouble #1
simonpd
New Holland tn 75 f
Bought a second hand Tn75f with engine troubles. 6000h - 1998.
I try to figure out where it has gone wrong.
So far i checked all minor things.
Fuel ok - pump ok - injectors tested and ok.
It was cranking ( very slow) but not firing up.
I ve tried this with the injectors removed and noticed 2 cylinders where not blowing any air out, nothing!
I m not a mechanic and so far my knowledge...
It seems 2 Pistons in the Middle are not moving.
What could cause this? Blown piston?
Piston 1 and 4 are moving and blowing air out, 2 and 3 just don't.
Anyone a suggestion what i can try myself ? I m out of options myself.
   / New Holland Tn75f engine trouble #2
I'm not a mechanic
Take it to one (or find someone to come out, that is). You could take the valve cover off for a look see first. Could be valves stuck, rockers broke, pistons/rings bad... Lots of expensive things, are possible. Hope you didn't pay much for it.
   / New Holland Tn75f engine trouble #3
pull the valve cover off to check the valve train, if thats good;
pull the oil pan if possible or the head.
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
