New Mahindra 3215 Pics
   / New Mahindra 3215 Pics #11
This tractor looks great, but the sub frame of the loader looks to be a little bit on the low side to me. Just how far off the ground is it?
Brian
   / New Mahindra 3215 Pics #12
Now Now Gamble. I think the Cub Yellow is very nice. /forums/images/graemlins/smile.gifI also think Mahindra Red looks good as well. The fact that the Mitsu. Engine and Drivetrain are under it make it a fine tractor I would guess. My Cub is tough and I don't regret the purchase one bit. I do hate paying Mit. OEM prices for things though. /forums/images/graemlins/frown.gif
   / New Mahindra 3215 Pics #13
What do these compare to size wise and performance wise to a Kubota? Would they be comparable to an grand L? Anyone know a price range for these? This model looks interesting..
   / New Mahindra 3215 Pics #14
Based on what I remember of the Grand L I thought it was a bit larger but I just went to Kubota real quick and it looks like they about the same size in weight and length. The new models should be every bit as good, actually better by the sound and looks, than the older Mitsubishi/Mahindra models.
   / New Mahindra 3215 Pics #15
The 3215 gear also has a shuttle. I can see now this is a good feature with a loader after several "if you can't find them, grind them episodes" with my non shuttle 2615! Live and learn and of course take just a little more time in between direction changes! 426DMB. /forums/images/graemlins/blush.gif
   / New Mahindra 3215 Pics #16
426 I'm confused by grinding gears on your 2615. My older Cub 7234, 23HP, is a full syncro and I can't remember having a problem grinding gears with it. Is your 2615 a syncro or straight gear? Thanks.
Its an optical illusion. The mounts are higher than the axles.
look carefully at the other pictures.
   / New Mahindra 3215 Pics #18
MajMac392,
The transmission description straight from the glossy sales brochure says it's a constant mesh on the gear shift and sliding mesh on the range selector for the 2615. The 3215 description says it's a constant mesh on the gear shift and a synchromesh on the forward reverse shuttle.
426DMB.
   / New Mahindra 3215 Pics #19
Ernie, in your picture that has the loader holding the front of the tractor in the air, the angles that are part of the loader frame that attach to the rear axle are clearly below the center of the tire. I guess the question that I want the answer to is, how many inches off the ground are these support bars? Other than that the new 15 series look great. /forums/images/graemlins/smile.gif
Brian
2014 International Durastar 4300 Terex BT2047 47FT 10 Ton Crane Truck (A50323)
2014 International...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
1997 Wells Cargo Enclosed S/A Trailer (A50324)
1997 Wells Cargo...
