New Massey
   / New Massey #1
kcook
Platinum Member
MI
Cub Lawn Tractor
Does Massey have a new line of tractors in the 1200, I saw an add for a 1233? Any one have any info!
Kevin
   / New Massey #2
Kevin,
The 1233 is a new addition to the 1200 series line.
   / New Massey #3
<font color=red>MF 1233</font color=red>
1.46 liter 3-cylinder IDI diesel
28.4 gross engine hp
27.6 net engine hp
70.4 ft*lb torque
9F x 3R gear transmission (no hydro available)
Total hydraulic flow = 8.5 gpm (6.0 main / 2.5 ps)
24.5 PTO hp
1980 lb lift capacity at 3-pt. hitch
64.6" wheelbase
116.5" total length
Total weight, w/ags., 2WD: 1800 lb
Total weight, w/ags., 4WD: 1980 lb
I knew I was keeping those brochures for something./w3tcompact/icons/wink.gif
   / New Massey #4
is the tranny on the 1233 synchronized?
i found a real good price (10k or 13k with a 1246 fel) on one not too far from here (about 100 miles) but don't want to make the trip to check it out if the transmission is a standard collarshift.
i don't do a whole lot of loader/dirt work, but enough that i don't want another gear grinding non-synched tractor.
charlie
   / New Massey #5
Charlie,
The brochure calls it either just "mechanical transmission" or a "sliding gear" transmission, which sounds like no synchro to me.
By the way, that is a great username you've got there.
Rob
   / New Massey #6
that's too bad. i really liked the rest of the specs.
can't take any credit for the username, i'm just borrowing it from george jones ;)
later,
charlie
   / New Massey
Are there any other new models?
Kevin
   / New Massey #8
Kevin,
There is going to be some new attachments and or equipment but as far as I know there isn’t another new model right now.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
