new member needs help... ih 254 wont stay running!!!
   / new member needs help... ih 254 wont stay running!!! #1
jdug
international havester 254
turn start key engine will start, climbs to high rpm & dies. feeling the manifold only 1 of the 3 cylinders is warm. combustion problem? please help!!!!
   / new member needs help... ih 254 wont stay running!!! #2
Is it a gas or a diesel?
deisel
   / new member needs help... ih 254 wont stay running!!! #4
You could have air in the fuel lines. Have you recently changed the fuel filter?
Check for bad fuel lines that may allow air into the system and fix this first. If you have air in the system it will have to be bled. To bleed the fuel system you need to purge the air from the system. There is typically a bleed screw on top of the filter housing to bleed the air out of the filter and lines leading to the fuel filter. Then you need to bleed the injector pump by cracking the injector lines on top of the injector and crank over the engine till you don't see air in the fuel that is coming out. Do all of the injector lines. Then try to start it up. If this does not solve your problem you may have a bad injector or an issue with the injector pump.
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
LOT: Flaring Tool Sets, Pipe Cutters, Brake Line Bender (A59076)
LOT: Flaring Tool...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
1289 (A58374)
1289 (A58374)
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
