new member owner of 1985 Yanmar Tractor
   / new member owner of 1985 Yanmar Tractor #1
CharlesCain
1985 Yanmar tractor
:confused2::confused2:Hello,
I am having difficulty with my tractor. I have changed fuel Filter and bowl, this is a diesel tractor, will only run for about 30 seconds then cuts off. I am thinking about purchasing a new tractor, not sure which tractors are safest. I mostly bushhog pastures, and move large round bales of hay around. I also am concerned about cost and easiest brands to work on myself instead of paying a high hourly rate to a mechanic.
   / new member owner of 1985 Yanmar Tractor #2
Welcome to TBN. :)
   / new member owner of 1985 Yanmar Tractor #3
:welcome::tractor: Possibilities---Go to the MAIN INDEX at the top left of this page. Scroll down. There are various subjects discussed from tractors, attachments; and every subject in between in these forums. You can also go to the website TractorData.com You will find info and SPECS there on many makes and models of tractors, in regards to engines, trannys, dimensions; etc. Good Luck. Happy Tractoring.:tractor:
   / new member owner of 1985 Yanmar Tractor #4
Hello & WELCOME to TBN!
I moved your thread to the Buying/Pricing/Comparisons Forum. :)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
Utility Trailer (A52377)
Utility Trailer...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
New Holland C185 (A47477)
New Holland C185...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
