New member, transmission question.
   / New member, transmission question. #11
Greg, buy another option! It's rare that more then eight speeds is needed or used on most tractors.
That was kind of my thinking also! Thanks for all the info guys.
   / New member, transmission question. #13
We have a 8540 with the 8 speed hydraulic shuttle transmission. It was one of the first series bought new in 2005. We use it with a 15 foot batwing bushhog and bale 4X5 bales of hay. Couldn't be happier with it. If you're getting a loader get the hydraulic shuttle but I wouldn't worry about the 12 speed.
   / New member, transmission question. #14
From looking at the 7040 specs and reading posts here, it appears the 4 creeper speeds that can be added with the optional cassette are restricted to slow speeds only and not heavy pulling. Does the cassette add a third "creeper" range in addition to the existing Low and High in the range transmission or does it turn the 4-speed main tranny into a 6-speed?
On the Kubota site, the 12 speed 8540 appears to have a 6-speed main transmission instead of the standard 4-speed. No mention is made of pulling restrictions in the lower gears. Are the lowest gears in the 12 spd. 8540/9540 OK for heavy pulling?
Bob
   / New member, transmission question. #15
Bob,
There are two questions: 4 vs 6 speed transmission and the addition of a creeper to existing of either 4 or 6 speed.
The standard tractor is a 4 speed with 2 ranges - 8 speeds
The 6 speed also has 2 ranges - 12 speeds.
If you are just doing loader or chore work, a 4 speed should suffice
If you want more speeds for mowing, making hay or a particular speed for spraying at 4 MPH, likely the 6 speed is what you want.
Either can have the creeper added to add another 4 or 6 speeds in the bottom speeds. The tractor does not have to be split and it is readily done in about half a day by first timers.
Unless you are harvesting vegetables or blowing lots of snow, you likely do not want a creeper. If you are pulling high draft tools in primary tillage, you would not use the creeper here either.
Hopefully this will clear up any misconception on the M40 transmissions.
Good luck!
2010 Ford E-450 Super Duty Transport Bus (A52377)
2010 Ford E-450...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
(INOP) 2018 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A51406)
(INOP) 2018...
