New Member with 1962 Ford 4000
   / New Member with 1962 Ford 4000 #1
charlesl44
Seattle, Washington
1962 Ford Industrial 4000
Looking to repair my Ford 4000 Industria tractor. The current project is how to replace a rear seal. I would like to use it.
   / New Member with 1962 Ford 4000 #2
Welcome to TBN. :)
   / New Member with 1962 Ford 4000 #3
Welcome to the forum from Oklahoma.
Ken
Thanks for the welcome. The 1962 Ford Industrial Tractor is doing fine now that all the bolts to the rear axel and differential are tightened. Everything was loose down there. Tightening things to spec helps. Now the new issue is the backhoe swing cylinders were rebuilt and the place doing the work said if they leak, there isn't anything more they can do about it. Well, one of them still leaks after being fixed. So I guess I need a new cylinder housing. Only thing is, I don't know where to get one. I also don't know if I can use the new guts. I also wish I knew how to start a thread in the Ford area. I will have to keep learning. Thanks again for the welcome, gotta go. Charles
   / New Member with 1962 Ford 4000 #7
Welcome to TBN :)
I moved your thread to the Ford Vintage Tractors Forum.
   / New Member with 1962 Ford 4000 #8
what rear seal did you need to replace?
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
CATALYST INJECTION TANK (A52472)
CATALYST INJECTION...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
