new member with 2120 pto problems
   / new member with 2120 pto problems #1
Chadho
Ford 2120
Hello fellow tractor enthusiasts.
I am the proud owner of a 1994 ford 2120. I have owned the tractor for 3 years and primarily use it for box blade work. Recently I started using it with a 72 finish mower. When under load the pto seems to do just fine but when it does not have load due to thin grass or previously cut grass the pto will disengage. The pto lever stays in the engaged or on postion. I have been reading through many threads but have not found any messages regarding pto troubles on my model of tractor. It does the same thing when attached to a post hole digger.
Any help would be greatly appreciated.:)
   / new member with 2120 pto problems #2
Welcome to TBN. :)
   / new member with 2120 pto problems #3
Hello Chadho,
Welcome to TractorByNet! :)
I moved your thread to the Ford/New Holland Owning & Operating Forum.
   / new member with 2120 pto problems #4
sounds like the pto shaft is not locking on to the pto stub. the shaft should click onto the notched portion of the stub.
   / new member with 2120 pto problems #5
The clutch controls the the PTO (live). Are you depressing the clutch when this happens. Is this 2120 a HSS?
12in Backhoe Bucket (A52748)
12in Backhoe...
2018 Ford Transit 250 (A50120)
2018 Ford Transit...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2025 Quality Steel Trailer (A50515)
2025 Quality Steel...
1992 TIFF Motorhome (A50324)
1992 TIFF...
Wolverine Skid Steer Concrete Bucket (A50515)
Wolverine Skid...
