New member with Mahindra Max 25HST
   / New member with Mahindra Max 25HST #11
isn't it still under warrentee?
   / New member with Mahindra Max 25HST #13
yes it would... good luck
   / New member with Mahindra Max 25HST #14
I would not mess with the fuel solenoid. I would check for a faulty relay or a loose connection before pulling any 'hard parts'..... Use schematic provided earlier to diagnose the issue to verify that it is the culprit first, then once identified pull/replace parts that are inoperable.
Based on your issue, it will run so long as you have the key in the start position?
I quote you, " The tractor starts, but will not stay running anytime until it dies. It will start right back up but then will die again and again and again."
Maybe I am mistaken? Perhaps a more detailed description of the issue would help us.
The electrical system has an order of event(s) before it is started. All safety switches must be energized in order for the glow plugs to work. This is evident when you switch the key to "run" as well as auxiliary power for your headlights will be energized. When you turn the key to "start" - other systems will energize; which is your fuel solenoid and starter. as the key is released to the run position the relay will hold the fuel solenoid until the key has returned to the "off" position.
I hope I wrote that correctly, my mind works faster than my fingers
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2015 DODGE RAM...
2014 INTERNATIONAL DF677 (A52472)
2014 INTERNATIONAL...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
