New Member
/ New Member #1
IronworkerFXR
Stamford CT
Ford, Kubota, County 754 , ASV , JD 410c
stopped by and joined have a 87 ford 1910 that has beed getting slow in the hydrolic area, now the 3 point arms don't lift also, have done fluid and filter change, that used to help now nothing. also how many of you have had water get into the hudrolic system on these tractors , mine has to sit outside.
JC
hope I can help otheres too
/ New Member #2
Welcome to the forum. Post your question in the ford area. You will get better response there.
/ New Member #3
:welcome: And bullet says hello too
/ New Member #4
Greetings and welcome to TBN. Winter and water in your Hydro fluids is a good combo for a very sluggish response. Water freezes. :thumbdown: Visit our Ford area. I read someone else was having similar problems and it cleared once inside and warmed up. So yes, it was water contaminated. Sounds like you need one of those Harbour Freight portable garages to keep it dry. TAke care.
/ New Member #5
It's easy to tell if you have water in the fluid, it will be milky colored on the dip stick.
