A drain plug with a good gasket only needs to be snug enough to not leak or work loose. If you are over tightening it, you are slowly destroying the threads in the drain pan nut. If you do strip out the drain pan nut, you will need to remove the oil pan and weld in another. Not a fun job. I suggest that you consider a replacement gasket and a new drain plug and see if that helps the situation. If you have already damaged the threads, there isn't any good remedy other than replacement. Many times when a person refers to "stripped" threads, they are referring to threads that have been pulled out. Cross threading is also another problem that requires replacement of the drain plug nut. Some resourceful people just re-tap the nut to a larger size, but they run the gamble that they will get metal filings inside of the oil pan. No matter how you do this repair, it is going to take you more time than you anticipate to do it correctly. If you use a shorter wrench to reinstall the drain plug, you are less likely to over tighten it. It is a matter of leverage, combined with your strength. If you have a habit of tightening things 1/2 turn before they strip, I suggest that you invest in a torque wrench to limit your ability to destroy things. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
