new owner 1600 ford ohio
   / new owner 1600 ford ohio #11
Check your service manual.. Diesels operate at much higher comp than gassers.. I'd expect 400psi+.. though i don't have ANY info on your specific engine..
Soundguy
   / new owner 1600 ford ohio #12
The one item to look for when running compression test is equal pressure between all cylinders. That is, it is better to have all cylinders a little low than one high one and a low one. You may have a head gasket problem.
Comp. test is next logical test. sorry, I do not know pressures of your engine. Dealer will be able to tell you "acceptable" numbers.
I took the injector's over to the local Ford dealer said they were working ok ,asked him about the comp. he said look for around 350 lbs. Now all I have to do is get a comp. gauge there's one on ebay that has a bunch of adapter's for checking through the injector and some for through the glow plug. One of the application's it say's it fit's is Kubota anyone know if this would work on the 1600? They had two 1600's over there one was $3995.00 and one $4995.00 both looked worse than mine in appearence course i realize that's secondary. I'am going to order a IT manual through the Motorbook Store in florida so I hope it help's . Mark
   / new owner 1600 ford ohio #14
Mark,
I have a service manual for the 1600 that I don't need anymore as I no longer have the tractor. I'd be happy to mail it to you if you haven't ordered one yet. If you want it, send me a pm with your mailing address.
Bob
Well thank's Bob that's darn nice of you but I just ordered a Clymer manual yesterday from Motorbook's and they said it shipped this morning but thank's for the offer anyway. Mark
   / new owner 1600 ford ohio #16
Mark,
No problem. It's just been sitting in a drawer for the past couple of years, so it would have been nice to be able to help someone out with it.
Good luck with the tractor.
Bob
Thank's Bob have a good day. Mark
Electric Concrete Mixer (A51573)
Electric Concrete...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
