New PT tucked away.
   / New PT tucked away. #11
On wrapping around a tree. I did it on the flats, I was mowing around a 5" alder and bang, I was stuck, back tire hooked a tree (no biggy I think) and then I try to back up, but because I was in a turn I just got myself closer, and closer. Frankly, all I could do was laugh and think of mikes pictures on the slope. And you guys are right, I do get used to the hydraulic lift sensitivity after a while. But, the dumping of the bucket and trying to get it to come down smoothly still eludes me. But, I have yet to get a PT Pucker to happen. Not sure it is possible on the 1850's. Maybe when I replace the front hydraulics with something a bit stronger...
Carl
   / New PT tucked away. #12
Here was one of my "passage rites". The hill was steeper than it looks in the photo.
Phil
   / New PT tucked away. #13
...and don't forget the picture with the first thing you "accidentially" back into!
I do recommend that you keep an attachment on (preferably a bucket or hoe) until you get use to it. This will help you to push your way out of whatever predicament you get yourself into. I keep both a front attachment on and the hoe on the back....I tend to put myself in a lot of places I shouldn't be:(
Enjoy
Jack
I am paying attention here! I only have 15 or 20 minutes of seat time so far, so I have a loooong way to go. I'll keep all this in mind, especially considering my land is about 98% woods. Farmall, I may look into those springs too. I am still a bit 'jumpy' on all the controls..
I should be spending alot of time on the machine this weekend. Hopefully, I'll have absolutely no stories to tell. ;)
Thanks again,
Jim
   / New PT tucked away. #15
Enjoy
Jack
PT's don't have the luxury of rear attachments :-( But I know what you mean...
   / New PT tucked away. #16
His PT does -- I think it's a 2425, though it may be a bigger one... :)
   / New PT tucked away. #18
Is anyone going to tell him the trick about getting off a tree without cutting it down after hanging it up on a hillside?
Or getting away from a fence once you drive up too close parallel and can't turn away from the fence without hitting it?
:p:p:p:p:p
Really! Please don't hold out on me! Spent a little time with the machine using the minihoe last night - obviously, I'm going to need all the tricks and advice I can get - this is going to take some practice. It is kind of tricky getting used to how it manuevers.
I'm all ears - Jim
:p:p:p:p:p
   / New PT tucked away. #20
:p:p:p:p:p
OK, as I recall, someone says you drive into the tree all the way around until you're down hill of it and slide away from it. I haven't tried it, but it may work.
But, when I was downhill against a fence, I dragged the 1845 sideways with a tow strap. What clever maneuver did I fail to figure out? :rolleyes:
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
17101 (A55787)
17101 (A55787)
Teakwood Dining Table (A55758)
Teakwood Dining...
2004 Mack CV713 Granite Fuel and Lube Truck (A55852)
2004 Mack CV713...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A55745)
2013 TEXAS PRIDE...
2020 LOAD KING JBTR-56 (A55745)
2020 LOAD KING...
