Newbury -
Here is what Stanadyne states, I don't see anything specific for a biocide...
Restores/Increase Horsepower detergents clean deposits in the injection system resulting in improved combustion, better acceleration, power, and torque
Reduces Fuel Consumption independent tests show an average of 4% improvement in MPG and gains up to 9.6%
Cetane Improver improves combustion resulting in better engine starting, smooth running, and reduced engine noise
Meets all engine fuel system requirements and will not harm exhaust aftertreatment systems
Reduces Emissions reduces Smoke and Particulates
Cleans and Protects detergents and deposit modifiers help protect injection pumps, injectors, nozzles, etc.
Reduces Wear lubricity improvers restore lubricity to ultra low sulfur and other low lubricity diesel fuels
Stabilizes Fuel - keeps fuel fresher and protects against formations of gums caused by oxidation
Cold Weather Protection improves diesel pour point up to 40ーF (22ーC), and cold filter plug point by up to 25ーF (13ーC), depending on base fuel
Corrosion Preventative Corrosion inhibiters will protect the fuel system from rust and corrosion
Helps Remove Water special demulsifiers cause tiny water droplets to come out of suspension/emulsion, so the filter/separator can more effectively remove water
Contains No Alcohol avoids corrosion and accelerated wear
Specially Formulated for use with ultra low sulfur diesel fuel
Can be used with Bio Diesel Fuel up to
B20 (20% bio content approved ) increased water separation shown in bio content up to
B20
Would you still add a biocide? Recommendations? Treat the tractor tank for gelling in the fall/winter or the storage tank? Or just treat it year round for gelling and not have to worry about it? What seems to be the go to for anti-gelling?
I'll let the water filter handle the water issue.
Like I said, I'd rather spend a few bucks more and not worry, especially since I have potentially a 3 year supply on hand. I tried to get a 150 gallon but had a hard time finding one. Plus with the minimum order quantity, the 300 just was the only choice it seemed. It'll save my back, my aggravation with 5 gallon jugs and allow me to save a few bucks on the off road.
