New T300 FEL Problems
   / New T300 FEL Problems
I received a possible fix action from LAWALLSTRACTOR. May be air leaking around rubber to metal surfaces on the suction side. They had a similar problem with a Mahindra model line before. I sent the info to my dealer for them to look into it.
Thanks, Galen, from NY on this info!
Les
From the increase of views of this thread, it looks like some of you are interested in what's going on...
Latest update: Dealer coming over to pick up Baby tomorrow. Going to take it back to their shop, replace loader valve again (still not convinced it is the valve this time), unhook all the lines and blow them out, flush all the hydraulic fluid, clean and double clamp the rubber to metal surfaces ( many thanks to Galen from NY on this!), and give Baby a working test to see if the problems come back.
I will keep you posted of the progress or regress...;)
Update - The dealer replaced the factory-provided joystick loader valve (3rd one on the tractor in 9 months), blew all the lines out, double clamped the rubber to metal connections on the suction side of the pump, refilled the system with new hydraulic fluid. They bled the air, worked "Baby" for a while and she did good at first, then like clockwork, began to get the same spongy cylinders and poor response in the FEL. They bled the system and repeated with the same outcome...(3 times).
Air is still getting into the system from somewhere. Not sure what their next move will be, but sure hope it is something soon.
I do have to say though, the guys at Coleman Equipment (Steeleville, IL), especially Kenny, have been super throughout this. Kenny offered up a "loaner" tractor for me while mine is out of commission. It is the TYM 433, and while it was tempting to accept his offer, it wasn't a factory-backed loaner and if something were to happen to it while I had it, it would be on Coleman's shoulders and loss.
I declined his offer at this time. I am not greedy. If corporate TYM sanctions the loan of a machine, then I will think about it.
More to follow...
   / New T300 FEL Problems #24
It seems to me that the only places air could be introduced into the system, would have to be a leak in the suction lines, filter, or the pump itself. The rest of the system would be under pressure.
   / New T300 FEL Problems #25
Les , how about a couple of photos of the lift and crowd rams on the loader . Where are the hose fittings , on top , on the side or on the bottom ? Are the lift rams double acting ? The dealer is just trying the same things over and over , they are bound to get the same results . Even if the the suction side has an air leak , you should just get a squawk out of the pump and a jerky response , the air should be able to get back out of the rams and self bleed . It should not accumulate to the point you can bounce the spongy loader by hand . If the hoses on the rams are on the bottom of the cylinders ie the rams are upside down , it would be possible for this to happen as the air would be trapped at the top of the cylinder .
I don't have the tractor close to take any pics of it. It is 70 miles from home right now. I did pull up some pics I found on a dealer's site and it shows the fittings on the sides of the cylinders for both the lift and curl.
I just got an email from my dealer and said TYM is sending out a new pump for them to try that. They are even sending a new set of curling cylinders, but we don't think those are the problem as the mechanic has tested them and they do not have any bleed-by or leaks, but who knows at this point.
I did relay the message about trapped air and they will look into it...thanks for the tip!
Les
   / New T300 FEL Problems #27
les. I have'nt read through all your posts, but have you tried bleeding the air by holding the fel lever in fast dump (regen) for a few secs?
My kioti gets the "floppy bucket" if I use the fel below about 1600 rpms. If I keep it reved up some it dosen't get floppy.
Yes...both the dealer and I have tried this. This was actually a recommendation from the factory to lift the loader all the way up and hold for 20 to 30 seconds and then curl the bucket down and hold for like time.
The factory also said I should be running the tractor at PTO speed to use the hydraulics.
I have been running all flavors of tractors and backhoes for 30+ years now and have NEVER had to run one more than 1,300 to 1,600 RPM to operate the hydraulics in a normal fashion. The exceptions being that more lift or power was needed for a short duration, but for normal operation, I will not run it like that. That is a good way to just tear up stuff quicker.
I appreciate the tip though, I am running out of ideas. You would think the Engineers at the factory would have some ideas...
If you think of anything else, please let me know.
Thanks,
Les
   / New T300 FEL Problems #29
These guys talk nonsense sometimes , running the loader at low revs ONLY has the loader working slower than at high revs . It will not cause air to get into the system , if that were the case , common sense would/should tell them that higher revs would cause more air .
   / New T300 FEL Problems #30
I am speaking from experience on my own tractor. Why in the world would I just make it up? I'm not a liar nor do I try to mislead people.
Running my tractor at idle while doing fel work causes a floppy bucket. It's something to do with gpm not keeping up with cylinder travel, this creates a void behind the cylinder causing the floppy bucket.
You need to do some research on the subject before you try to discredit my response.
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
Electric Concrete Mixer (A51573)
Electric Concrete...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
