New TBN iPhone app attachment
   / New TBN iPhone app attachment
Thanks I'll check it out.
I use "My Home" a lot when accessing TBN with a computer and was frustrated that you have to add an extra step with this app by going first to the "more" menu. Maybe some of you have already figured this out but it is actually quite easy to modify the bottom screen menu and add the subscribed threads option (=my home).
Go to the "more" page, hit the edit button at the top, then grab the desired function and drag it to the bottom menu panel. I added the "subscribed" option in place of the logout button. Simple as that.
   / New TBN iPhone app attachment #53
OK. That's not what jcims said, though.
To clarify the above, 4.0.1 on my 3GS was awful (for me). It was basically unstable, and would crash on a regular basis...almost daily. I've since updated to 4.1 and it is vastly improved. I don't believe it has crashed once since the update.
I have noticed one thing, however, and I don't know if it's hardware or software. But when the battery is marginal (say 7-10%) and I either start up an app or take a picture, there will be times when i'll hear a little snap from the speaker and the phone just goes dark. If i was taking a photo at the time, the picture will not have been saved.
I've also noticed the 'GSM sound' (that sound you can hear through speakers if the phone is too close) can now be heard coming from the earpiece speaker as well. Could just be the phone.
   / New TBN iPhone app attachment #54
Thanks JC, I knew what you meant;)
I have still not done the S/W update:confused2:
   / New TBN iPhone app attachment #55
Thanks for the info IT:thumbsup:
To clarify the above, 4.0.1 on my 3GS was awful (for me). It was basically unstable, and would crash on a regular basis...almost daily. I've since updated to 4.1 and it is vastly improved. I don't believe it has crashed once since the update..
I'm still having trouble with 4.1. Not nearly as stable or fast as 3.x. The TBN app hangs regularly (solved by closing and restarting) as does the NYTimes app. Both just basically fail to update the screen and become unresponsive. Clearly an operating system issue as neither app had any problems under 3.x.
   / New TBN iPhone app attachment #57
I had a 3G running 3.1.2 and now an iPhone4 which ran 4.0 and now 4.01 and both were jailbroken and I have never had any problems with either of them.
   / New TBN iPhone app attachment #58
I have 3GS that started on 3.X. Upgraded to 4.0, then 4.01 then 4.02 and now 4.1. No trouble with any apps on any of the OS releases. Some apps haven't caught up with R4.1, but you can't blame that on the OS.
Mike
I keep making the mistake of upgrading the OS so that the currently available jailbreaks don't work. Be very careful before going to 4.2 as they have made it even harder to go backwards.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
Deer Target (A57149)
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
