New tires on my 1984 Chevy Ton truck and now the back end seems to be
   / New tires on my 1984 Chevy Ton truck and now the back end seems to be #11
Do some burnouts.
looks like u don't have enough tongue weight. i have a 2001 4 door chevy 1 ton dually an when i load anything on trailer i first measure the bumper height and after loading make sure bumper goes down at least 1" to 1 1/2". if not heavy enough the trailer will fishtail. i have a 20' car hauler with steel bed and have hauler more than i care to remember. if you have to, bring out a bathroom scale and measure the tounge weight on the dolly wheel. my trailer is long enough to pull forward to get that bumper drop. that backhoe i think is heavier than loader and engine. hope this helps
I'm pretty sure I have plenty of tongue weight...the new tires feel this way with JUST the truck.....and with the trailer too.....I'm going to try to get some miles on the new tires and see if it settles down.....the old worn out tires felt solid as a rock....while pulling the tractor too
   / New tires on my 1984 Chevy Ton truck and now the back end seems to be #13
as mentioned before tread depth is causing it, make sure they are air up to max pressure
   / New tires on my 1984 Chevy Ton truck and now the back end seems to be #14
   / New tires on my 1984 Chevy Ton truck and now the back end seems to be #15
I was always told that the culprits are both the taller lugs and the release compound used to free the tires from the molds. It supposedly takes about 400-500 miles for the compound to wear off. I can't say I noticed on my 1/2 ton, but the stock tires-cheap OEM Wrangler SR-As-were so miserable that the new BFG AT KO-2s were heaven in comparison.
   / New tires on my 1984 Chevy Ton truck and now the back end seems to be #16
As they wear down they will become more stable , we have seen this on our work trucks, more in the 22.5 & 19.5 with the " winter deep" tread. Hence the "deep" maybe too deep giving feeling of un stability
Sent from my iPad using TractorByNet
13 ft trailer waverunner (A51694)
13 ft trailer...
SHOULE RM8080 LOT NUMBER 115 (A53084)
SHOULE RM8080 LOT...
JOHN DEERE 54D LOT NUMBER 146 (A53084)
JOHN DEERE 54D LOT...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
