New to forum and Satoh S370D
   / New to forum and Satoh S370D #1
JeffinNB
2016 Branson 2400h with SL00 FEL
Hi all, I picked up a new to me Satoh S370D a month ago. It wouldn't start so I pulled the head and found a cracked rear piston and seized rings on the front piston.
I replaced both pistons and rings after lightly honing the cylinder bores. It started right up after and seems to run great and everything works.
It came with a Woods RM48 finish mower and 48 inch Berco snow blower, FEL and custom cab.
I do have a hydraulic leak coming from the 3 point piston cylinder head. I'm thinking it's likely the o-ring. Anyone happen to know the size?
Thanks
Jeff
   / New to forum and Satoh S370D #2
Congrats on your new machine and welcome to TBN. I'd give Valley Power a call, they'll be able to help with any issue you might have!
   / New to forum and Satoh S370D #3
Thanks
JeffView attachment 759403
At the top of this section is a pinned topic. Download the helpful PDF there for your machine.
As for o-rings, Buna-N or Neoprene are the two for hydraulic use. Other materials will fail due to not being fluid compatible.
Japan tractors are made to JIS standards, not SAE. With this stated, the o-rings are metric.
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
Golf Cart (A55787)
Golf Cart (A55787)
CATERPILLAR 308E2 CR EXCAVATOR (A52709)
CATERPILLAR 308E2...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
