Molalla1
Elite Member
I believe your tractor is a MCrD Tier 4 emmisions engine. You need to run it at higher RPM. A 'warm up' RPM of 13-1400, then crank her up to 2K or so an run it there. Since you have been working it at 1K RPM, your ECR is probably sooted up and needs to be cleaned. Then you will be good to go. Once it is warmed up, you can idle her at 1K, but she needs more RPM when working her. On my 2555, the EGR cleaning process is to unplug the electrical connector, remove the two bolts, remove the EGR being carefull with the reusable gasket. Then clean the exposed soot off with brake cleaner, blowing it dry at the end. Replace the EGR and you are good to go. I had a dealer mech clean mine once, when I abused my motor like you have. Never had a problem since. I believe the flashing of the CPU gives a little more voltage to the EGR to help it move. Once it binds up from the soot, you get the smells and poor engine running. Surprised you do not have a ' Check Engine ' light on.
Very good info for him Jerry . . . :thumbsup:
