NEW TO ME B7100D hydrollic problem
   / NEW TO ME B7100D hydrollic problem
well you guys got it working for me, i needed to put the 3 point linkege lever in the back position and it works magic hey, well i will be starting work on the backhoe tommorrow and hopefully it will be ok,
thank you all very much for helping me,
william
   / NEW TO ME B7100D hydrollic problem #12
No problem. I figured that was it. It took my awhile to figure that one out with my hydraulic blade. I'm currently trying to figure a way to hook it up so i dont need to do that, doesn't sound right to me....if i figure it out i'll let you know. Good luck with your new tractor.
   / NEW TO ME B7100D hydrollic problem #13
hi I just got done redoing a b 7100 I had the same problem you had I eventually changed the controll valves to the hyd block because the block is a preasurized line you have to use a power beyond type of controll valve so the fluid stays presurized thru the valve and back to the other port you also have to run a third hose back to a tee off the fill plug witch is probably where your tank port on the current valve is plumbed that also allows you to be able to run a three point hitch and a loader at the same time i was able to buy the block adapter from my dealer if you need any part numbers or more indepth let me know it took me about a month to figure it all out also what brand of backhoe is on your tractor
   / NEW TO ME B7100D hydrollic problem #14
Yah thats what i figured. My dealer told me there should be two hoses coming off that block and i only have 1. I dont really use it much so i dont plan on fixing it for awhile, but thanks, didn't know where to get the adapter.
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2017 TAKEUCHI TL10V2 SKID STEER (A60429)
2017 TAKEUCHI...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
