TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,084
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
Hey guys I need some advice,
I have a kubota BX2200 and I just replaced the shut off solenoid and the engine switch and I still don't have power on the red wire that goes conected on the solenoid. I traced the wire and it ends under the dash board on a 4 wire terminal. Now my question, should it be a relay of some kind connected on it and if it is what's it called?
Sorry I can't help with that; anything electrical and off to the dealer for me.
Thanks for all the nice comments. The more I play with the bx2200, the more I like it. I decided to go ahead and do a complete fluids service on it, so I went by the Kubota dealer today, and bought oil, air, hydro, and fuel filters. Also bought 2.5 gallons of SUDT2, then over to Walmart for 5 qts of Shell 5w-40 synthetic.
Had to order upper and lower radiator hoses, but they should be in by Thurs. I already had 2 gallons of prestone long life, and distilled water on hand for the coolant change.
So, add another couple hundred to the price.
Sooooooo, what have I missed?
K
Did you do a front axle fluid change?
These things don't require a lot of maintenance. I use an air compressor to keep the screens clean and blow the grass out of the deck and grease all the fittings; back U joint is kind of hard, but you get use to it.
They make an improved seat for it I think, but ours has the original.
