New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas?
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #41
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #42
Okay, then other.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #43
Any thoughts?
The first thing you need to do ASAP is to prevent anyone from step into the hole. If that happens you could loose all your property via a liability lawsuit even if the person is a trespasser. :judge:
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #44
Put a rounded drain plug in it. They are impossible to remove.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #45
Nope! This mystery should stand on its own until there is evidence of collusion. If you are so inclined to believe it is related to pallets or drain plugs then vote for 'other'. If 'other' wins, we will have to take a deeper dive.
If you dive into that hole you may get your head stuck in it!
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #46
Hang on, Pallets were never offered as a solution or explanation for the "deep,deep skinny hole", they were strongly suggested as a safety measure to cover & mark the position of the "deep, deep skinny hole".
If placing two pallets in an inverted 'V' over the "deep, deep skinny hole" results in furthering the continuing investigation into the mystery of the "Pallets in Fields" conundrum, the all the better!
2010 MULTIQUIP 25KW GENERATOR (A58216)
2010 MULTIQUIP...
Gas Engine Water Pump (A57454)
Gas Engine Water...
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
UNUSED FUTURE D39 39" HYD TRENCHER (A58376)
UNUSED FUTURE D39...
2019 GMC Savana 3500 12ft. Box Truck (A56858)
2019 GMC Savana...
BOAT MUD MOTOR (A58376)
BOAT MUD MOTOR...
