New to mowing hills... what are safest mowing patterns?
   / New to mowing hills... what are safest mowing patterns? #21
If you have a smart phone, there is an app for finding degrees of slope for it. Most folks go by the pucker factor. If it is uncomfortable in the seat mowing side slope, as in you are sliding out of the seat, then it likely needs to be mowed up and down. Unless it is really steep at the turning point, then you can likely just make a sharp turn at the top and head back down.
If it is really steep, I will straight back up the slope then turn at a slant slightly at the top so that the tractor is almost aligned with the next mowing path and then turn back straight and mow back down.
From your photos, it looks like only one parcel is steep enough to require backing up and that is the upper right area and it may even be too steep to mow even backing up. With R4 tires, you will likely loose traction when backing up if it is too steep to mow. I have mown pond dams that were over 45 degree slope and would loose traction sometimes backing up. You dont have to worry about flipping forward when backing up a hill or going down a hill in a straight line. The bushhog is your counterweight to help avoid this.
NOTE: If you start loosing traction (rear wheels sliding) when travelling up or down a hill, just work it like sliding on ice, steer in the direction of the slide so as to keep your direction of travel going straight down the hill. DO NOT LET THE TRACTOR GET SIDE WAYS AS IT MAY FLIP.
   / New to mowing hills... what are safest mowing patterns? #22
I know, have driven those but the point was wider track, those small tractors are quite low and should be very stable if you increase track width.
   / New to mowing hills... what are safest mowing patterns? #23
Put the tractor in 4wd when on slopes. Tractor brakes are only on the rear wheels. If you're going down a steep hill in 2wd, the rear end gets light and the brakes are less effective. When in 4wd the rear brakes will slow the front wheels too, so you effectively have braking on the front.
I mow in reverse a lot. You can get the mower into more places. Twist around to the right in the seat to look back as it's easier to reach the hst pedals. Some rotary cutters have tailwheel brackets made from thin metal strap. Those will bend if you back the mower into a stump or rock. Some people run the stabilizers loose when mowing so the mower can move side to side some. Some telescoping stabilizers have slotted holes for this. The idea is that the mower will move sideways if it hits something. I like to have the mower in a predictable position so I can mow close to fences and trees, so I just try to be careful. I mow with my hand on the 3pt position control so I can raise the mower quick if I need to.
   / New to mowing hills... what are safest mowing patterns? #24
I'm next state over...Virginia, blue ridge area not all that far to WV and very hilly here also.
Now this is going to sound stupid...but I'd rather be safe than sorry.
I have a couple of Cub Cadet zero turn mowers I use on the worst parts, 50" deck.
The center of gravity is low, very safe, sometimes I mow everything with them (it takes a few days), usually cut just the worst part along property lines then bush hog the better parts.
Worse case with Cub is although I'm leaning way over it can scoot downhill...but no problem or danger.
I like to bush hog downhill if it's steep. I would not want to turn on a steep hill. When I mow first a few rows that gives me a safe place to make the turn.
If it doesn't feel right I don't do it. A few places I have bush hogged straight uphill.
Yesterday a fellow here delivering lumber got a large flat bed truck stuck. Another guy on a skid steer made ruts and almost turned over. We've had rain, ground very soft. I wouldn't mow now for anything.
Nice looking place.
Good idea about walking the area you are going to mow, before hand. Also, your tractor probably has some documentation about slope capability, that you might want to review.
Thanks! We love it.
I am a manual reader, unlike my husband. I will sit and read the manual cover to cover before operating this tractor. I will be looking for that documentation, thanks!
VERY helpful info! Thanks!
   / New to mowing hills... what are safest mowing patterns? #27
I don't know how steep the land is that you want to mow. On my tractor I've had to raise my bush hog and also the three point hitch finish mower slightly to keep the high side tire from losing traction on the grass. One time it was only the gauge wheels on the finish mower that kept my tractor from rolling over.
I bought a set of tires to use as duals and that has saved my bacon many times.
I wish I knew how to rotate the images so they show the way they are supposed to. I am not mowing grass up side down!
So, pictures are hard to get a real good sense of it, but here goes.
First one is a panorama, and I measured the left slope at its steepest, and it痴 70ー. The opposite side of the bowl is also 70ー. In the middle is a swale that is going uphill away from the camera for about 1200 feet, give or take. I dunno, maybe 10-15ー tops? Not a problem. We mowed the center and lower slopes in our 8N last year, and this new tractor has to do better than it did, with its wider front wheels and loaded back tires.
Our orchard (next pic) is also clocking in at 70ー, and we went up and down it with our 8N. (It痴 level at the top; no problem to turn around.
Last picture is our front yard and hill up to the pasture (across our driveway). I measured it at its steepest, near the top, it is 65ー. My husband JUST managed to mow that cross hill on our 8N, but it sure looked scary.
   / New to mowing hills... what are safest mowing patterns? #29
I'd have a 4 point ROP to start. a 2 point has killed many before. you only live once. then only mow up and down the hill. there are mowers connected by a long arm, where the tractor can remain on level ground, and the mower angles for a very steep incline, but that's only good for about 10 feet or so from the tractor. I've seen those used..
   / New to mowing hills... what are safest mowing patterns? #30
My approach is pretty much like Gary's though I will mow diagonally in some places and in some places will pick up a bucket of dirt for counter balance. To start with determine if an area really needs to be mowed and how soon until you become more comfortable with your equipment.
Land can be tricky, just because there are no obstacles are present now doesn't mean there won't be next month, we are talking about hills and a washout can appear really quick. A low bucket has saved me several times.
Beware of a missing or poorly calibrated pucker-meter.
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Enmark Z Spray (A53316)
Enmark Z Spray...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
iDrive TDS-2010H...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
