StrangeRanger
Hi,
I've acquired an OLD, about 4' rotary cutter and have questions. Once I clean it up a bit I'll post pics. It's literally got weeds and stuff growing on it so I can't even begin to imagine what brand or model it is. But it looks old.
The PTO shaft looks like it drives a pully/belt system that in turn drives the gear box. I'm thinking I can clean this up, grease the zerks, dress the belt and see what happens. I'm planning on the belt breaking so I'll simply replace it when it does. For now I've rigged up basically a bungee cord for a belt tensioner.
But the PTO shaft that was w/ it is too short. So I'm assuming I can replace this w/ an extendable shaft (assuming I can fit the plastic housing between the braces). That shouldn't be a problem right?
It looks like it might have had a gerry rigged rear wheel at some point in its life, but it is long gone. Any reason I can just run it w/out a wheel. I'm simply using it to cut down mostly weeds along the drive and in a field. So I figured I can just set the height w/ the 3pt and leave it there.
The blades are beefy, but basically square they're so un-sharp. But do you really need sharp blades for something like this? Will it be sufficient to clean them and the underside of the deck up and go?
If anyone has experience reconditioning old equipment like this I'd love your input. It's a relatively small little cutter and I'm thinking my L3400 should have no problem w/ it. Assuming I can find a PTO shaft to fit.
Thanks!
j
Thanks!
j
