New Toyota Tundra’s Recalled for Spun Crank Bearing
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #151
Never had a pan leak on any of our vehicles. I did have to replace the pan on my '97 7.3 Turbo diesel because it developed a corrosion hole in the front from road salt up here however but none of the pans have ever leaked. Sounds like the gasket wasn't applied when the engine was built to me. Poop happens sometimes. No reason to abandon a brand because of assembly error far as I'm concerned. That can happen to any brand, foreign or domestic.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #152
LS oil pans are know to start leaking. I've not had one start leaking on me, but I know people who have, and it's a PITA to fix if you're a DIY'er. Ford EB (especially the GEN1 2.7L EB which was notorious for developing leaks) are known to sometimes develop leaks as well.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #153
Even class 8 trucks now. Kenworth already announced as part of it meeting the new greenhouse gas emissions that are being rolled out, only 10% of their new trucks will be able to be ordered with a manual transmission.
This is getting ridiculous.
Manual transmission is already phased out in Europe, to make the numbers in the test cycle improve.
Daf (Paccar) built a... Well is it an X15 ? Daf calls it a Paccar PX15 i think. 660hp, with improved torque over the X15 . Tested in Australia by Daf, they worked together on this Paccar specific version.
Anyways, Daf sells it in Australia with the bigger engine. If they would sell it in Europe, the theoretical average fleet consumption would go up and they would be heavily fined.
Meanwhile they miss out on the heavy haulage market where the Germans offer the same 660hp and the Swedish another 100 more. Just crazy...
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #154
If you do heavy haul like I used to do prior to retirement, a servo controlled auto don't work. We always ran 18 speeds simply because an auto cannot split the necessary gears when running way over gross on permit loads plus they return terrible fuel mileage.
Even my farm truck is an 18 speed. I would never own an auto shift, against my grain actually and my personal vehicles are all standard transmissions as well.
Clutches for me are optional anyway. Only time I clutch any of them is when I stop and start. Other than that, I float all the gears. Same with my farm tractors. Never replaced a clutch ever and I don't remember the last time I adjusted any either.
If I told you what my 3406 Cat in my Western Star long nose conventional is putting to the rear wheels, you'd fall out of your chair. Lets just say quite a bit north of those engines. It ain't T4 either so every shift produces smoke, just the way I like it. Guy down the road has a Freightshaker cabin over with a 1693 TA Cat in it and it's a rocket ship loaded or empty. The 1693 is my favorite engine followed by a 3406 B model. Of course his and mine have Jakes on them and straight pipes too.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #155
I wouldn't, I ran E9 V8 Mack's.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #156
It's really all in the injection pump and older Mack's and Cats have the same proven (but now antiquated by emission controls) pump design. Interestingly, my Kubota's also share the same pump design and are also easy to 'turn up' and I did, well my Kubota tech did. Didn't bet stupid with it, only 10 ponies.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #157
Maybe Eaton just doesnt have its software right. Volvo and Scania build their own automated manuals, up to 780hp and up to 250 ton GCW in heavy haul spec. They do incorporate a crawler gear, for positioning at low speed, or taking off from hills.
ZF builds their AS-tronic and TraXon transmission with offroad mode, so it shifts at a higher rpm so a 50 ton 5 axle dumptruck doesnt fall still in the sand trail while shifting.
Without power assist clutch, i prefer to leave the pedal alone too, shifting with the throttle is easier.
Though nowadays you only see Eatons on historical truck shows in Europe, they are no longer on the option list since the late 80s and synchromesh with air assisted clutch pedal has become the standard for over 40 years here.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #158
Love the Allison Automatics for hauling off road. One less chance to f-up a gear or foot slips off the clutch crossing a ditch or through soft ground.
I’ll never go back to a manual transmission.
Life’s too short to row gears while working a truck.
Autos are great. Just jump in and drive. Prove your manhood in other ways. ;)
Although I did just find a Pete 335 tandem with a Cat & Eaton 10 speed and a 24’ flatbed. Perfect for large square bales…. wish it was an auto…
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #159
The part you miss is, Scania is not sold here (yet) because they are not EPA certified and they are all cabin overs and COE's haven't been popular in this country for decades. Last COE was the Freightliner 'Argossy', I believe and it was a flop. Things may change at some point but not in my lifetime or yours.
First tractor I owned was a cabin over and I was never thrilled about being first on the scene in an accident, with the radiator cap. never was. Interestingly, my long nose Star is more maneuverable in tight situations than my cabin over ever was and same applies to the conventional company tractors I drove for over 25 years. So long as the wheel cut is set correctly, they maneuver just fine.
Never had an air assisted clutch, never needed one either.
   / New Toyota Tundra’s Recalled for Spun Crank Bearing #160
I would never buy any unit with a 10 speed. Only thing they are good for is pulling a lightly loaded dry box and if it's a Super 10, run away and don't look back. The 'Super 10's' are interfaced with the throttle and the throttle must be completely dropped before you can change gears. Consequently, you cannot float the gears at all.
Again, the 10 speeds are dry box, light load units plus the reverse is somewhat high so backing will be a chore and hard on the clutch as well.
I'd never have one and I've driven them before. Crappy tranny.
I agree the Allison's are good in a HD pickup application but again, you have to keep up on maintenance or your wallet will bet appreciably lighter, real quick as they are expensive to work on and must be repaired by an Allison certified repair facility, not some shade tree wrench. Always use Allison fluid and Alison filters as well.
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
UNUSED CHERY INDUSTRIAL 10' - 18 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
