New tractor...what MUST have tools for maintenance?
   / New tractor...what MUST have tools for maintenance? #31
GeneD14 said:
A few years ago I had my 3,800 lb Allis D14 sitting up on 4 Sears jack stands rated at 4,000 lbs each. I thought the safety factor was more than enough...wrong.
As I was working on the tractor with the 4 wheels off: one of the rear tires which weigh about 200lbs gently tipped over and hit the side of the tractor. That small side impact was enough to make all 4 jack stands crumple and the entire tractor slammed down on the floor! It scared the @*%&%$#) out of me!
Now even when I'm under a 3,000 lb car I use a set of heavy duty jack stands (rated for 5 tons) or I use solid blocking.
I saw a demostration (done at a local Police Dept) once where a former auto thief took 4 of the old (10 oz. I THINK) Coke bottles and placed them under the suspension of a car. He then removed all the lug nuts. Next, he let the air out of the tires. The cars weight was supported by the Coke bottles. That allowed him to remove all 4 wheels and tires. Then he gave a shove to a rear quarter panel. That shifted the cars weight ever so slightly, crushing all 4 Coke bottle. Down went the car. He said he'd stolen HUNDREDS of tires and wheels that way.
The old car hit the ground with quite an impact. It doesn't take a lot to hold up dead stationary weight, but add a little movement and BANG.
I keep several 6"X6"X12" wood blocks in the shop. Jack stands may fail, but those blocks won't if they're placed correctly.
   / New tractor...what MUST have tools for maintenance? #32
normde2001 said:
whisk broom
That was the first tool that went into my tractor's tool box, after I had to walk back to the barn to get one to clean off the radiator/screen when mowing.
   / New tractor...what MUST have tools for maintenance? #33
I've seen this done with 4 red bricks to a co-workers truck once. Only difference, they left it up on the bricks.
   / New tractor...what MUST have tools for maintenance? #34
Lots of the right type of shear bolts and the proper tools for them handy.
Bogh lottsa stuff from Messicks. I also bought an impact tool.
   / New tractor...what MUST have tools for maintenance? #35
YM2610D said:
Just bought '06 JD 3720 with FEL, rotary cutter, etc, since it's my first new one, would like some assistance on what tools and equipment are a neccessity to have and own so as to keep it operating as it should. I'm going to order everything I think I might need at one time from Harbor Freight in the next couple of days. ANY help would be appreciated.
You need a pair of 12" wrenches to be able to adjust the top link of the 3pt.
a good grease gun with a flex line end
a good grease gun with a solid line end
a phone call to the dealer - have the shop take the blades of the cutter out and apply anti-seeze compound to the big azzz nut/bolt that holds on the blade.
4" or 4-1/2" angle grinder to sharpen the blade on the cutter.
3/4" socket, extension and breaker bar to allow you to get off that cutter nut when it's time to change the blades. Good ones as you need to give 5-600# of umph to get them loose. More if they are rusted on.
About every thing else is gravy and can be bought when needed. (then you can get a couple of extra's....)
   / New tractor...what MUST have tools for maintenance? #36
Jeez guys, come on. Not 1 mention of the most important things, stereo in garage, refridgerator, couch and maybe the most important a card table for when your help shows up when workin on a project. Startin to wonder about you guys Ron
   / New tractor...what MUST have tools for maintenance? #37
Those things go without saying ---- so we didn't say.
That's my story and I'm sticking with it.
jb
   / New tractor...what MUST have tools for maintenance? #38
A good pistol pump oil can is good to have. For hard to reach places.
Gear wrenches are nice, and a Leatherman.
Solo
   / New tractor...what MUST have tools for maintenance? #39
I have to admit I did not read all the post. Sorry if this is a repeat. I realized that I would like to have a pressure washer. So I got one. I like to blast everything clean to perform maintenance.
   / New tractor...what MUST have tools for maintenance? #40
Change to "maintain performance" to justify... :)
My must-haves?
manuals
grease gun
collection of lynch pins, hair pins, and just plain pins
adjustable wrenches of various sizes (a wide-head 8" lives in my front pants pocket)
pipe wrenches, Vice Grips (not no-name)
complete set of combination wrenches
1/4, 3/8, 1/2, and 3/4 inch socket sets (1/2 gets the most use)
screwdrivers, allen keys
kits for o-rings, spring pins, gaskets, grease fittings
hammers (nailing, 4lb sledge, ballpeen, deadblow)
brass drifts of various sizes up to 1.25"
air compressor and accessories(tire inflation, cleaning, tools if you're in a hurry)
floor jack, bottle jack, scissors jack, jackstands
LARGE selection of bolts/nuts in the flavour your tractor/equipment uses
tool boxes, organizers, and wall racks to help keep things accessible and from getting lost
those're what come to mind- buy the other stuff as needed.
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
