Ballast New truck: weights, towing capacity
   / New truck: weights, towing capacity #51
And I'm in deep do do now. I had the torque tube break on my ink pen, the axle snapped on it and, I over filled my spell checker with toner. :eek: Now mah spel chekr iz dun broke! :D It be a bad bad dey!!
Sorry, ah wo gets off da subjeck no mo. :eek:
   / New truck: weights, towing capacity #52
I drive a 2500 Ram CTD. So I was reading all of these wonderful "manly" post, and discovered something that was not discussed. I see this kind of discussion on many boards and can't believe fuel milage did not come up. Nobody made the claim about their manly diesel (that cost more than gas since I bought mine) getting 28mpg. That is all that is missing except for tire ratings. JC
   / New truck: weights, towing capacity #53
Okay, I have 46 ply tires and pulling 20k behind my truck at 110 mph, I still get 67 MPG. There, how's that? :D
   / New truck: weights, towing capacity #54
Are those 16 or 17 inch bush hog solid tires? How many fuel magnets are you running? Now all you need is to get hooked up with the guy that sells off road fuel before it get the red dye. JC
   / New truck: weights, towing capacity #55
Well at least your spell checker is fixed...
   / New truck: weights, towing capacity #56
Oh yeah? Well I added the in line fuel atomizer, the intake turbocharger, the water injector, an economizer chip, and the electronic fuel ionizer to my truck, plus I waxed it with superslick NASCAR race wax to reduce air friction and now I have to stop every couple hundred miles to drain the fuel tank. Each of those (except the wax) gives me an extra 25 to 30% more mpg, so I produce fuel as I go down the road. It gets annoying trying to give away diesel at someone's gas station.
   / New truck: weights, towing capacity #57
*ROFLMAO* U all are killing me...
On the fuel mlileage... I have been a little disappointed so far with my Cummins.... only gotten about 13... I think... only checked it once so far, but the overhead 'puter says 15-16... AND I was told the 'puter usually is UNDERstating... Not sure what to think... will get a better check with the 3 horse slant loaded to the gills going to a show in two weeks....
   / New truck: weights, towing capacity #58
Highbeam said:
Lots of people are hung up on 3/4 ton vs 1/2 ton when they haven't actually done the math. Neverenough, perfect name, falls in this category since it is apparent that he likes his truck and assumes that we all need the same thing. It is true that a 3/4 ton can do everything that a half ton can do and more so I can see where folks like him would dismiss the lesser trucks without close examination of the load to be carried, empty weight, current ratings, etc.
I would like a one ton truck too. I like the idea of increasing the safety margin, but, I will not fault someone for using their truck to its rated capacity.
Let me explain REALITY to you a little, seeing as you just aren't getting it and need to start getting personal to defend yourself. Ford, for example, uses 2 styles of axles on their light duty line of pickups (note: even though they call them "SUPERDUTY", they are still in the light duty catagory). The half ton trucks use what is commonly refered to as a semi floating rear end. The inner axle slides into the carrier and is held in place by a retaining clip. It just "floats" in the carrier. The outer part of the axle has a bearing pressed on it, right next to the flange to mount the wheel. I have broken a few axles between the bearing and the flange. Know what happens when it breaks there??? The tire, wheel, flange, and BRAKE DRUM, seperate from the vehicle! Not real safe hauling a large load. Now in the case of Ford 3/4 and 1 tons, they use what is refered to as a full floating axle. The tire, wheel, and brake drum, are mounted to the axle housing with a bearing on either side of the assembly, locked onto the housing with 2 large retaining nuts. The axle then slides into the housing and the axle flange is bolted to the rotating assembly. The axle carries NO weight at all, it "fully floats", it only transfers torque from the rear gears to the outer wheel assembly. The axle housing carries the weight.
So, you can read numbers until your eyes fall out, but the FACTS remain, if you use a half ton to it's capacity too much, axle failure will happen. Been there, done that! Yes, I have lot's of experience loading half tons to their capacity, and I also know, if you do it a lot, they will start breaking. You will also prematurely wear out the axle housing and the seals will start leaking. At this point, you have to repair the housing, or replace it. This is why I stated in my post it would be ok to do it once in awhile, but if you do it often, you need to move up to a 3/4 ton.
   / New truck: weights, towing capacity #59
Yes, I agree "neverenough". I would have posted something similar but I have ole HB on my "ignore" list. When it is clear that I cannot possible learn anything from someone and, they give wrong, and at times dangerous, advice, I just do not want to even read it. I hate to act like I use people, but if I cannot gain one single bit of useful information from someone, I just don't care to read anything from them. Anyway, good and factual points.
   / New truck: weights, towing capacity #60
Since this thread has gotten so goofy, guess I may as well throw in my 2 cents. The last guy I seriously dated dumped me because he said my butt was too small. Do you think if I ate one of those giant slurpys everyday that eventually I would look like Dargo's wife or concubine love machine or whoever and that the guys would be flocking this way?
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
Rhino V152 (A50121)
Rhino V152 (A50121)
2001 Sterling L7500 Series VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A50323)
2001 Sterling...
Caterpillar 330FL (A50120)
Caterpillar 330FL...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
2021 John Deere TS Gator (A50121)
2021 John Deere TS...
