ihuntbear
- Joined
- Jan 19, 2010
- Messages
- 430
- Location
- new brunswick, canada
- Tractor
- 2015 tym T554 and 1999 Kobota m4700
whats the deal with these new stabilizer bars.The old style.all you had to do is raise the attachment then tighten up the bar by hand or pipe wrench until the sway is out of your attachment.The ones I have on my new tractor I have to raise the unit,pull the pin from the stabilizer,then turn the bar until I think its tight enough then swing the attachment toward the stabilizer that I'm trying to tighten then try to put the pin back in.if it doesn't go in I either have to wiggle the attachment a little or if I gave the stabilizer to many turns ,turn the other way until the pin goes back in.way to much bull****.Or am I doing this the wrong way? on My stabilizer bars one end is threaded and the other end has a pin.It would be much easier if both end were threaded like a tie rod end.Turn one way and it extends or turn it the other way and it
retracts:confused2::confused2:
